20 Most Recent Kenmore 15762 Dishwasher Questions & Answers
I had an E4 error
Hello Neil,
You may just need to reset the washer having cleared the error code. This can be done by holding the PROG button for about 3-5 seconds.
The snowflake is the rinse aid warning light and the tipping cup with the S is the low salt warning light. These shouldn't be related to the problem and should disappear when they are refilled.
If holding the PROG button doesn't reset the washer, you need to check whether any water has leaked under the washing compartment. Either remove the kick-plate under the door and check for water visually or pull the washer out from under the counter and tilt it backwards about 45 degrees. The washer is heavy and the bottom can slide out when you do this, so get someone to help you if possible. It's also a good idea to put some old towels on the floor under the back of the washer to catch any water that drains out.
Please try this then let me know if you need further assistance. You didn't specify a model number, but from the description, I'm assuming this is the KDW12ST3A? You can reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
3/14/2023 11:17:29 PM • Kenmore 15762... • Answered on Mar 14, 2023
My sears kenmore dishwasher model #665 is not
The lower spray arm being loose is a normal condition. The first thing that needs to be checked is that the holes in the spray arms are clean and not blocked. Next once the unit has filled with water, the water level needs to be checked. If it is too low this will be what we need to repair. There is a float assembly in one of the front corners the water should be very close to the float. If it is not there is either a restriction in the fill line, water fill valve or the main board. You should be able to listen to the fill time and that should be around 55 seconds. After these tests are done I will nee the information to continue the diagnosis.
9/10/2019 4:05:44 PM • Kenmore 15762... • Answered on Sep 10, 2019
Why will my dishwasher not start?
this sounds like the user interface {touch-panel} has gone bad
12/15/2017 11:38:07 PM • Kenmore 15762... • Answered on Dec 15, 2017
What is this part? http://postimg.org/image/cn92pu2c1/
H'mmm, I can't say that I recognize that part. It might be part of the middle or upper wash arm assembly, but I don't know for sure. If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
3/23/2015 5:28:19 AM • Kenmore 15762... • Answered on Mar 23, 2015
Door won't latch
replace door latch ***'y
12/12/2013 2:25:37 AM • Kenmore 15762... • Answered on Dec 12, 2013
Wont fill with water
assuming the kitchen tap is ok and water pressure is normal, it is likley the dishwasher inlet valve is not working. Refer part 16 on this diagram.
9/22/2012 9:27:43 PM • Kenmore 15762... • Answered on Sep 22, 2012
How do i get the lock off my dishwasher
Hi
If you are referring to the Child-lock feature which deactivates the buttons from use then usually on Kenmore dishwashers you can deactivate this child lock by holding the "No Heat Dry" button for 4 or more seconds. This should get the panel to respond again.
Hope this helps. Please do rate my answer. Many Thanks.
11/27/2011 7:06:58 PM • Kenmore 15762... • Answered on Nov 27, 2011
The water is not draining
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
3/20/2011 3:28:40 AM • Kenmore 15762... • Answered on Mar 20, 2011
The water is not draining.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...Dishwasher Problems - Water will not drain outheatman101
3/14/2011 3:31:37 AM • Kenmore 15762... • Answered on Mar 14, 2011
Soapy residue left on bottoms of glasses or where
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
3/3/2011 1:15:34 AM • Kenmore 15762... • Answered on Mar 03, 2011
White residue
heatman101
2/20/2011 8:05:21 PM • Kenmore 15762... • Answered on Feb 20, 2011
2answers
Following rinse cycle, dishes are covered with a
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
1/11/2011 2:30:39 PM • Kenmore 15762... • Answered on Jan 11, 2011
0answers
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
9/25/2010 9:25:23 AM • Kenmore 15762... • Answered on Sep 25, 2010
Hi there, I have a kenwood dishwasher KDW12ST3A an...
For the manual, try this link: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW12ST3A.pdf
hope that helps
8/18/2010 9:55:59 PM • Kenmore 15762... • Answered on Aug 18, 2010
When I choose a cycle on the actuator dial and
http://www.servicematters.com/maytag_library/docs/16010622.pdf
Above is your service manual.
Below is a DIY troubleshooting site to help you along with your service manual to isolate and troubleshoot your issue.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
When this happens usually it is either a sensor, or the Controller board that has been spiked. or the water may not be coming in, because the Inlet Valve may be stuck. You MUST perform the troubleshooting steps, to sort it out.
8/11/2010 10:24:01 AM • Kenmore 15762... • Answered on Aug 11, 2010
Kenmore 15762 Dishwasher Logo
68 questions posted
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dishwashers
  • Kenmore Dishwashers
Most Popular Question
men cod e4
  • Dishwashers
