Ge frig won't defrost new mother board, heater, and thermostats. it still won't defrost i jump the 2 wires on the mother board and the heater turns on but won't cycle it keeps building up frost
Replace the thermistors #4 and #5 . 4 is the white bullet looking piece on top of the coils inside the freezer , with 2 white wires . 5 is at the bottom of the freezer , on the left side . These thermistors tell the main board , the temp and the board goes into defrost according to temp the thermistors "tell it " .
SOURCE: GE GSS22SGMC BS s x s freezer frost build up
Jake, the green wire is the ground, just attach it to one of the screws the secure the cover plate. As far as you ordering both the heater and the board, you have it covered. Catriver.
SOURCE: GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
SOURCE: My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
SOURCE: My freezer was developing frost / not cooling very good.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
SOURCE: GE GSS22SGMC BS s x s freezer frost build up and I
This problem is usually caused by a blown defrost heater in the freezer. Unplug the refrigerator, remove the back lower panel inside the freezer. Defrost the aluminum evaporator coils. At the bottom of the evaporator is your defrost heater with two wires going to it. Remove the two screws holding it on and pull the heater out carefully. You will usually have to jockey it from one side to the other to remove it. It is a glass tube heater with an element running through it. If it is blown, it usually is black. You can do a continuity test on it also, to be sure. If it is good you can easily see the complete heater inside the glass. One of the wires goes up to the defrost thermostat which is usually clamped onto the top of the evaporator. Inspect this also to see if the top has seperated from the round base or if it is pushed out. Replace if it has blown. You can only do a continuity test on this if the defrost thermostat is colder that 50 degrees. This is a very common repair, I carry two of the replacement defrost heaters, and I always check for this first when I see a defrost problem with this model. Good Luck, Appliance Specialists
