Having trouble installing. Only have 1 black , 1 white and ground in wall socket. Switch has 4, line,load,neutral and ground.
Connect timer white wire to bare ground wire. This will complete circuit to 3 watt timer mechanism, and while this action is not 100% code, it will not pose much risk since the wattage is so low.
Copy following link for illustrations and information:
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Leviton-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
SOURCE: How does the illuminated light work inside a
The neon lamp inside of the switch draws very little current (milli, or mico amps) so there is no significant current flowing to ground.
As for your real question, there are several various types of 3-way pilot switches:
Load on: Pilot on
Load off: Pilot on
Some 3-way pilot switches have an external lead which allows them to be configured either way.
If both of your switches are the same type and are wired correctly, they should work the same.
If you suspect that one is defective, try swapping them.
Testimonial: "Thank you very much. It turns out one of the two was simply dective. Thanks!"
SOURCE: I am replacing a combination 2 switch using a
First, turn off the power to this circuit to avoid getting a shock.
If the two devices that are controlled by the combination switch are lights, you will want to join the two (2) white (neutral) wires together with a wire nut, as these are not connected to the switch.
You also want to connect the bare copper wires (ground) together and connect one of them to the switch's green grounding screw and IF the wall box is metal, you also need to attach the ground wire to the box with a green grounding screw.
Now, you can connect the wires that go to your lights, the red and black wires that are part of the same wire and are routed to the same location thru the wall box. Take either the black or red and connect them to the screws on the side of switch that are not connected together with the small brass strip between them. Put the red on one of these screws and the black on the other.
Now with the black wire that is the hot (Common), this is the one that is bringing power into the wall box, should be connected to the other side of the switch, the one with the two (2) screws that are joined together with the brass strip between them.
This will allow you to turn on and off each of the lights (or a fan, etc) separately with each switch sharing the common power source.
Here's a picture of the switch that shows the side of the switch with the common side and the brass strip that connects the screws together. This is the side where the one black (hot / common) wire that supplies the power gets connected.
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=8935§ion=10070
You can also open up the box the switch came in and you'll find a wiring diagram for the switch that illustrates how to properly wire the switch for your application.
I hope you find this Very Helpful and best regards!
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
