The white wire is used to power electronics inside timer:
Single pole switch has two insulated wires.
Remove both insulated wires from switch.
Timer black connects to one of the insulated switch wires, or to Hot wire from breaker
Timer red connects to the other insulated switch wire, or to Load wire going to fan, light, motor.
Timer white connects to Neutral wire from breaker box. Neutrals are white wires that are twisted together and pushed to back of box.
If box does not have Neutral wires, then connect timer white wire to bare ground wire.
Timer green connects to bare ground.
Turn power on, and check if timer is working. If timer is not working, then reverse timer black and timer red wires.
This wiring information has been tested and is accurate.
If timer does not function correctly with correct wiring, then move timer to another location to see if timer is defective, if timer does not work on specific Load, then noise or interference on line can be suspect. Also check ratings for timer and compare with Load ratings.
If you have countdown timer connected to whole house motor/fan, then horsepower rating is important consideration. If timer is rated 1/6 HP and whole house fan is 1/2 HP, then timer will not work.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
