The steering wheel was turned when the key was removed. So when you try to turn on the key, turn the wheel one way and the other way to release the pressure on the key. The key should turn ok.
Hope this helps.
If you have a spare key try that first. Also try trurning the steering wheel back and forth while you try to turn the key.
If those two don't work than remove the key and tap the lock cylinder with the handle end of a large crew driver several times. Then try the key. Repeat this several times it should eventually turn.
If the key does turn after tapping than replace the lock cylinder IMEDIATELY. The key needs to be in the "run" position in order to remove the lock cylinder. If you can't turn the key to this position you will have to drill the lock cylinder out to move it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
SOURCE: 1999 Ford Taurus with only 1 key
a good locksmith cant program the key. this is a dealer item. hope this helps.
SOURCE: stuck ignition cylinder 1992 ford taurus
It is not necessary to have the dealer do this, think of the cash! Though it does require patience and time. The pin you are supposed to push in goes into a slot when you have it in run position, since you cannot turn it to run you have to make a slot for the pin to go into, with a drill. Be very careful as you only have a 1/4" of play before you break a washer behind the cylinder. Once you have drilled out the key far enough to the pin hole you can take a nail set and tap the pin up, you can tell when the pin clears the housing, then it just takes wiggle, patience and tinkering to get the cylinder to slide out, keep the green washer and the metal slot washer. Metal slot washer goes in first with green plastic washer ontop of that with lock cylinder in last. You can play around with the new lock cylinder and washer before insertion to determin correct direction.
Here are official directions with inoperable lock cylinder. They say drill out retaining pin but it just spun in circles for me - I looked at new cylinder and saw how it worked. retaining pin needs a place to go.
Removal & Installation (Non-Functional)
NOTE:Use this procedure to remove ignition lock cylinder if key is missing or cylinder is frozen.
Disconnect negative battery cable. Disable air bag system. See appropriate AIR BAG RESTRAINT SYSTEMS article in RESTRAINTS. Wait at least one minute for air bag back-up power supply to deplete. Remove steering wheel. See STEERING WHEEL . Using a 1/8" bit, drill out retaining pin located below lock cylinder on housing. DO NOT drill deeper than 1/2".
Using channel lock pliers, twist lock cylinder cap until it separates from lock cylinder. Using a 3/8" drill bit, drill down center of ignition lock key slot about 1 3/4" until lock cylinder breaks loose from its base.
Remove retainer, washer, and lock cylinder gear from housing. Remove metal shavings from lock cylinder bore. Replace housing if damaged. To install, reverse removal procedure. Connect negative battery cable. Check air bag system for proper system operation. See appropriate AIR BAG RESTRAINT SYSTEMS article in RESTRAINTS.
SOURCE: 1996 ford taurus ignition switch
It sounds as if the rod or ignition key gear may be broken. The ignition switch is actually on top of the steering colume under the dash. The key turns a gear that is connected to a rod. The rod travels down to the actual electrical ignition switch. If you are not feeling any tension at all when you turn the key, either the rod or gear has broken. In either case the steering wheel all the way down to the key tumblers will need to taken apart. Hope this helps.
SOURCE: Intermittent fuel pump engagement when turning key - 2001 Taurus
try cleaning the connector that goes to the fuel pump, sometimes they corrode on inside. If that does not fix, test the wires feeding fuel pump with a multi meter until the condition shows itself again, if voltage drops to zero or very low then wiring problem, if voltage is unchanged with problem and fuel pump is not working and connectors are all clean, try replacement of fuel pump.
SOURCE: 2001 ford Taurus. Will not start. Turn key and
The problem would be the starter they go without any warning
Testimonial: "Terian5- Thanks for the help Traced the wire to starter. the wire looks like it snaps on. put it back and it started. I need to tighten nut."
