The tv is on, but there is no sound available. i have tried turning the tv off and on, changed the batteries, made sure it wasnt on mute, and made sure all the cords were connected in the back of the tv. one minute i was watching tv, the next no sound. mute is not on.
SOURCE: Sceptre LCD TV power come on, but there is no picture or sound.
There are two easy fixes you can try. Both require you to take the back panel off. If you are not comfortable doing this, take it to a repair shop.
UNPLUG IT.
Place the TV face down on a soft/solid surface.
After you get the back panel off, there are three silver boxes. There are white and black wires leading from the off switch to the top silver box. Take the cover off that box.
Inside is a ceramic fuse. Test that fuse. If it is blown, your local electronics shop can find a replacement.
If not, disconnect the white and black wires from the PC board. Remove the 6 screws holding it in place.
Look for scorch marks under the board.
Cut a thick piece of plastic and tape id down over the scorch marks.
Re-attach the board with the six screws and re-connect the black and white wires.
Turn the power switch to the OFF position and plug in the TV.
Turn on the power switch while WATCHING the board you just removed.
If you hear a sizzle, turn off the switch and get a thicker piece of plasic.
If not, the TV should come back on.
Re-assemble the silver box and put the back on.
Hope this helps.
SOURCE: Half of the screen turns black after 10 mins 46" Sceptre LCD TV
YOU PROBABLY HAVE DEFECTIVE LCD PANEL THERE IS A SLIGHT CHANCE IT IS THE MAIN BOARD OR THE LVDS CABLE
SOURCE: My Sceptre X32GV-Komodo got a problem recently: I
This type of issue is usually caused by blown capacitors on the power supply board. If you wan to do the repair yourself then go to our web site at: www.ccl-la.com/capacitors.htm and look at the pictures of what to look for in your monitor. Now open the unit and look for the power supply board, replace all parts hat look like the pictures and have even slightly bulging tops. The page on our wen site gives more information about the replacement parts. If you need to order parts we do stock them for same day shipping. If you don't want to do the repair yourself we do offer a repair service for your model for $45 plus return shipping. Let us know if you have any additional questions by email at [email protected].
I hope this helps you, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: No picture and no power LED
Hello. I have the exact same tv. and the same thing happened to me! What i did was buy a expensive Surge Protector and now it works! I hope this info is useful!
SOURCE: new Sceptre 37" LCD TV does not turn on
I just got a 42" komodo by Sceptre, same problem, except "SCEPTRE" showed on the screen. I was sent a USB key program to insert in the service slot in the back and it reflashes the bios. This is old news for you but maybe new for someone?
