SOURCE: Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
SOURCE: Hotpoint oven model rgb745wea1ww oven doesn't
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
SOURCE: Model: JDS8850AAS -- Oven won't preheat above 150
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Hope this helps
Gene
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
