It appears its on a timer, but we don't know how to turn the timer off if that is the case. This has happened twice in 2 days.
You do not have its user manual with you I assumes. Click here to download the user manual to your TV. Refer it. It will have all details you want to know.
SOURCE: SONY XBR 60" STANDBY
Check the door for the lamp...over time mine distorted from the heat, and this was an error code for the door now being closed. Temporarilty I wegeded something in there to hold the switch closed, but ended up replacing the door.
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
SOURCE: Tv will not turn on. Standby Light flashes twice.
UNPLUG AND TAKE OFF THE BACK AND CHECK THE FUSES,,MGT BE BLOWN,,
SOURCE: Flashing Standby Light - Sony 40 in Bravia
Similar problem. Unplug for 36 hours solved the problem.
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
