We've changed the water filter in our KitchenAid refrigerator (long overdue), and pressed the water filter button 5 times, but the light is still red. It's supposed to change to green after pressing. We turned the refer off, then on, then tried pressing 5 times. Still no luck. Any ideas?
Most models also have a filter indicator reset button located in the same area. After changing the filter, reset the filter status light by pressing the Filter Indicator Reset button or by pressing and holding the Filter button for 3 seconds. The status light will change from red to green or the status display will change from "Replace" to "Good" when the system is reset.
If your model has a water filter indicator, but no reset button, press the light switch in the refrigerator compartment 5 times within 10 seconds to reset the system. The status light will change from red to green when the system is reset.
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Try push and hold, light stays on red (not turn green).
