I can play any dvd in my dvd drive without any problems. No audio problems while watch a dvd but when I record and then burn to a dvd disk all audio cuts in and out. The video burns just fine. Just not the audio. I have updated my drivers but still having problems. How do I fix this problem
SOURCE: can't watch my burned dvd's on dvd player
You must get software that makes the DVD into a format compatible with ya DVD player. get software that will encode whatever ya have into the right format such as ConvertXtoDVD D/L link here. www.shareup.com/ConvertXtoDVD-download-44697.html This proggy takes whatever Movie etc that ya have and converts it into a DVD Player format that can be used in PC & on DVD players..
SOURCE: Burned CD's won't play in auto CD player
what type of disks are you using
possibly try a different brand
also cd/rw mostly dont play back
SOURCE: My Lite On DVDRW will not recognize any audio cd's...
Hi PhxROcker,
In these drives there are two lasers and two pick-up sensors. Normally in a combined head. One set is used for the DVD and the other is used for the CD. From you description it sounds like the optical sensor for the CD laser has expired! When you place a CD into the drive a small amount of information is read by the drive that identifies the disc type, manufacturer, it's status, capacity etc. If the drive cannot read this then it thinks nothing is present.
If you insert a disc does the LED on the front the the unit flash a few times while it spins the disc. Does it do this repeatedly? If it fails to read the disc does the LED stop blinking and the drive no longer spins the disc? If this is the case then your drive may indeed be faulty.
Sorry I could not be of any further assistance.
Regards,
Spare head 2.
SOURCE: lite-on dvd drw lh-18a1p
Media Center Edition 2005 XP - Will not burn with any of my software, NERO, SONIC RECORDNOW OR MICROSOFT.
SOURCE: Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
http://download.cnet.com/magicdisc/3000-7970_4-10383679.html
MagicDisc Virtual CD/DVD-ROM is a utility designed for creating and managing virtual CD drives and CD/DVD discs. MagicDisc Virtual CD/DVD-ROM emulates audio, data, and game CDs and DVDs with ISO image, CD and DVD images. MagicDisc Virtual CD/DVD-ROM offers 200x speed and noiseless CD/DVD access without a physical drive. It supports creating up to 15 virtual drivers. You can run games, software, see movies (VCD, SVCD, DVD), and hear music directly from your hard disk without inserting and swapping CDs and DVDs. MagicDisc allows you to use almost all CD/DVD image without burning them onto CD or DVD in order to easily access your favorite games, music, or software programs. It works like a real CD/DVD-ROM: You can run programs, play games, or listen to music from your virtual CD-ROM. It can compress ISO CUE MDS NRG CCD image; can encrypt ISO CUE MDS NRG CCD image; can make ISO image from CD/DVD; It can mount UDF only CD/DVD image and multi-session MDS/MDF and CCD/IMG image.
hope some of this helps you
