Hey everyone
i can't seem to get a live headphone feed out of my phones outputs on the firewire 410 card to monitor the levels and the sound at all. i want to multitrack and hear whats going on in the card whilst its happening?
i also want to make use of the spdif in to make it a real 4 in [unlike what i thought it was when i bought it] and want to know if i can run a feed out of my edirol r-09 [which has an optical out - minijack though] into the spdif in [via the RCA in or coaxial]... is this possible and if so, how?
thanks. really would appreciate any help at all.
looking forward to hearing from you...
bhakti
SOURCE: M-Audio FireWire 410 External Distorted Playback...
Hello have you disabled all the built on sound cards on your computers? This is a known problem. If you are going to use a great product like M-audio disable any onboard audio card. Then try to use the 410 system. If you still have the problem try changing the latency to 4-5
SOURCE: m-audio firewire 410 problem
Hi isterix!
I also have a 410 on a acer 1502 laptop with xp. I installed the latest driver (5.10.00.5053) and i have sound (after changing sound preferences in panel control) but it makes me peaks in the playback. I think it's due to the driver, that is the same also for windows vista. I'll try to install the previous one and i'll tell you!
SOURCE: RECORDING GUITAR USING AUDIOPHILE FIREWIRE AND GUITAR RIG 3
I've ran the audio in on my sound card to my mixer and had the guitar on the mic in. I've also ran the line in to a small cracker amp. Keep it turned down. If I would directly connect it use an adaptor. I haven't tried using a 1/4 to 1/8 adapter and directly connected to it as I wanted to control the tone. I don't see why it wouldn't work. Keep everything muted and turned all the way down when you first connect it. Then start raising volumes slowly I will try and report back As far as spdif you're just recording analog to digital conversion. I get more realisitc sound just keeping it analog til it hits my line in. Have a quality sound card. Not some walmart special. I use Adobe Audition 1.5 to multichannel record.
SOURCE: UNABLE TO INSTALL FIREWIRE 410????
I got the same problem, but cannt find out or google it how to reset the device, found just some scripts, cannt use that, do you have some help?
THANKS
