The green "clean" light just keeps blinking. If I push all the right buttons to start a new cycle, the dishwasher won't start a new cycle. Instead the clean light just keeps blinking? Any ideas?
Sears charged me $200 upfront the technician came and did the exact same combination of keys in sol # 3 and worked and it didnt take even a minute. I called Kenmore and Sears for help before setting up the appointment. They never offered this solution through phone. They said we have to come and take a llok. absolute rip off !!
Replace control panel /board
Thank you! It worked for me!
Close door then push heat dry then normal heat dry ld light up. then push then normal again. then push start or cancel. it will happen again because there is is a problem. the problem is with your heating element or your control board. seek a pro.
SOURCE: Green clean dishes light blinking
Hi If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information. Daniel
SOURCE: "Clean light" keeps blinking; dishwasher won't start new cycle
It says in the manual to check the heating element.
Clean light keeps blinking
Clean light keeps blinking. Tried solution #2 but best solution I could not find.
same as above
I have same problem. need help pls.
[email protected]
(562) 239 7608
Same problem. I don't have a heated rinse button but if I push any sequence of buttons it then goes to the blinking quick wash button. no matter what I try it will not start a new cycle.
On my new Kenmore dishwasher, the green light just keeps blinking no matter what I push. I tried powering down for a minute and that did not work. What do I need to clean and I'll do it?
green clean light keeps blinking. Manual says to check heater circuit? How do i do that. How do i fix the heater circuit?
I tried the sequence normal wash, heated dry, normal wash, heated dry as well as hi temp wash, heated dry, hi temp, heated dry- none of these sequences worked. Unless I'm doing it wrong.
The model I have is 665 16012403
I would greatly appreciate any help, suggestions, magic tricks, anything anyone can offer. Thanks so much in advance.
G od bless.
our dishwasher will not start, the clean light is blinking continusly
