Roland VersaCAMM VP-540i Logo
Posted on Jun 29, 2012
MOTOR ERROR 00900080 - Roland VersaCAMM VP-540i
My ricoh photocopier machine is giving error code 522 pls what is the solution
Quoting link:
"This error is a fusing thermistor error, it can mean:
The fusing lamp is not connected. Reconnecting it may solve the problem.
Thermistor is bent or gone bad. You may need to replace it.
Or, the thermistor position is incorrect.
To try and reset the code press:
Clear Mode, 107, Clear/Stop and hold for 5 seconds."
http://terraofficesolutions.com/forum/index.php?topic=7.0
http://www.thecopierexchange.com/2017/01/updated-ricoh-error-codes/
Code
Possible Causes
SC500Main motor/transport motor lock/Fusing motor error
SC501Drawer 1 lift motor malfunction
SC5022nd or 1st tray lift motor malfunction
SC503Drawer3(or 2nd) lift motor error
SC504Drawer 4 or 3rd lift motor malfunction
SC505LCC Tray malfunction
SC506Paper tray motor lock
SC507LCT main/feed motor lock
SC508Rear fence drive motor
SC509Drawer 3 LCT right fence error
SC510LCT lower limit error
SC511LCC motor lock
SC515Drawer left guide drive motor error, Tandem rear fence motor error
SC516Drawer 1 side guide motor error
SC520Paper tray error/Duplexer jogger drive motor error
SC521Duplexer jogger driver motor error 2
SC522Duplex-Side fence jogger HP error
SC524Duplex-End fence jogger HP error
SC530Bypass feed motor lock/fusing fan motor error
SC531Fuser/Duplexer reversing motor error
SC541Fuser thermistor open/ Hot Roller thermistor open
SC542Fuser Temperature warm-up error
SC543Fuser overheat error1
SC544Hot roller fusing lamp lower limit temperature detected
SC545Fuser lamp overheat error 2
SC546Fuser ready temperature malfunction
SC547Zero cross signal malfunction/ Fusing temperature does not increase
SC548Fusing installation error
SC550Fusing web end
SC551Pressure roller thermistor open
SC552Pressure roller warm up error
SC553Pressure roller overheat
SC554Pressure roller low temperature abnormal
SC555Pressure roller ready temperature abnormal
SC557Pressure roller temperature does not increase
SC558Zero cross signal abnormal
SC590Exhaust/Fusing fan motor error/used toner collection motor error
SC591Toner supply motor error
SC592Toner bank motor error
SC599Copy exit tray motor lock
Troubleshooting Tips:
SC500:Too much load on the drive mechanism
Some gears or other rotating parting has been jammed.
Developing unit is over toned.
Main motor or its driving board is defective.
Before replacing motors or sensors, first check the mechanical load.
SC 541:Fusing thermistor open:
Machine is plugged into low line voltage.
Fixing thermistor is defective or out of position.
Some loose connection
Power Supply board defective
SC590:Left exhaust fan motor error
Loose connection of the exhaust fan motor.
Too much dust in the fan causing too much load on the motor driver.
(e) 6XX: Communication errors
CodePossible Cause
SC600Communication Error Between Main Control and Operation Panel Boards
SC634Key/ Card Counter Device Error
SC636Communication Error Between BICU & Paper Feed Control PWA
SC696Communication Error Between Engine Boad and Finisher
SC621:ADF connection error
An incorrect ADF is installed on the machines.
The connector of the ADF is removed while the machine is in the energy save mode.
(f) 7XX: Peripherals Problems
CodePossible Cause
SC700RADF Original Pickup Malfunction
SC702RADF Feed Motor Lock
SC703RADF Transport Motor Lock
SC704RADF Original Exit Motor Lock
SC705RADF Bottom Plate Motor
SC721Sorter Bin Motor
SC722Finisher/Sorter Jogger Motor
SC727Finisher Stapler Rotation error
SC728Finisher paper stack height error
SC733Finisher Lower Tray lift Motor
SC760ADF Gate Abnormal
SC770Display Editor Abnormal
SC700:ADF pickup problem
Home sensor is defective
ADF board or pickup roller mechanism is defective.
SC733:Finisher lower tray lift motor
stack height sensor or lower tray limit sensor may cause this problem
(g) 8XX: Controller Errors
CodePossible Cause
SC800Startup Without Video output End
SC804Startup Without Video Input End
SC818Watchdog Error, Software Malfunction
SC819Kernel Mismatch, Download Firmware again
SC820Self Diagnostic Error,Download Firmware again
SC855Wireless LAN card problem detected
SC857USB Interface Error Detected
SC868Incorrect Data is detected in the SD card
SC870Address Book Data stored on the hard disk was abnormal
SC 826:Self diagnostic error:
NVRAM on the controller board is defective and must be replaced.
SC855:Wireless LAN card error
Poor Connections between LAN card and the printer
Defective controller board.
Defective wireless LAN card.
Disclaimer:
Please note that this detail is just for information. Do not try to repair a machine if you are not a qualified technician. Technicians should also not take this information as a substitute of technician manuals.
Message is Service call error 00010014 I have an Epson Stylus pro 9800 and I am getting a message saying: Service call error 00010004 error 00010004 SERVICE CALL 00010004DescriptionFailure of ...
Epson Stylus Pro 4400/4800/4880 Error Codes
• Maintenance Request Codes:
• 0002 - CR Motor near end of life - Replace carriage return motor ASAP
• 0006 - Battery shut off - Replace RTC back-up battery
• 0040 - Cleaning unit near end of life - Replace cleaning unit ASAP
• 0080 - Date not set - Set the date through the printer control panel
• 0088 - RTC backup battery not installed - Install RTCbackup battery
• 0100 - RTC backup battery pressure is temporally low - wait for a while
• 0200 - The number of ASF paper feeding has reached predetermined value
• Service Call Codes
• 00000101 - CR Motor reached end of life - Replace carriage return motor
• 00010000 - PF encoder check error
• 00010001 - PF motor is out of step
• 00010002 - PF motor overcurrent has occured - Replace PF motor
• 00010003 - PF motor out of postion time-out error
• 00010004 - CR encoder check error - ensure enoder strip is clean & dust free
• 00010005 - CR motor out of step - click here for more info
• 00010006 - CR motor over current
• 00010007 - CR motor out of position time-out error - Replace the board assembley, main
• 00010008 - Servo interupt watchdog time-out error - Replace the board assembley, main
• 0001000A - Carriage home position detection error
• 0001000C - PG home position detection error
• 0001000F - CR motor PWM output faulty
• 00010010 - PF motor PWM output faulty
• 00010012 - CR overload (high sensitivity) error
• 00010013 - PF overload (high sensitivity) error
• 0001001B - Head Driver (TG) temperature error
• 0001001D - CR servo parameter error
• 0001001E - PF servo parameter error
• 00010020 - CSIC reading/writing error
• 00010022 - Ink type error (setting on printer body side)
• 00010023 - RTC analyzing error
• 00010025 - SCIS ROM communication error
• 00010026 - RTC communication error - click here for more info
• 00010028 - Head error - replace print head
• 00010029 - Unidentified NMI
• 0001002A - CR ASIC ECU error - Reinstall/update firmware
• 0001002B - PF ASIC ECU error
• 0001002D - Cleaning unit has reached end of life - replace cleaning unit
• 0001002F - 360 DPI writing time-out error
• 00010030 - Multi sensor error
• 00010031 - ASF phase detection error
• 00010032 - ASF drive switch error
• 00010033 - Eject phase detection error
• 00010034 - Eject movement error
• 00010035 - Pump phase detection error
• 00010036 - Type-B board installation error
• 00010037 - Head thermistor error - Replace print head
• 00010038 - Transistor thermistor error - Replace board assembley, main
• 00010039 - PG adjustment value incorrect overwrite error
• 0001003A - PG adjustment value outside range error
• 0001003B - Cutter installation error 1
• 0001003C - Cutter installation error 2
• 0001003D - Cutter installation error 3
• 00020000 - NVRAM error - Replace board assembley, main
• 00020002 - SDRAM error - Replace board assembley, main
• 00020003 - Boot program SUM error - click here for more info
• 00020009 - Flash memory SUM error
• 0002000A - Program load error
• 0002000B - The internal memory is insufficient
• 100000E0 - CPU address error (load)
• 10000100 - CPU address error (store)
• 10000180 - CPU reserved command code exception error
• 100001A0 - CPU slot undefined command exception error
• 100001C0 - The AC power is shut off
• 100005C0 - CPU DMA address error
• 10000xxx - CPU error
• 0003xxxx - Debug orode
• 0Dxxxxxx - An error code for debugging
• 0Exxxxxx - A time-lag of the RTC timer
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Fan connector
motor error - ensure nothing stuck in fuser - remove from printer, try new print cartridge
A motor error occurred.
x = description 0-motor error
2-motor start-up error
3-motor rotation error
1. Turn the printer off, and then turn the printer back on.
2. Make sure that the fuser or toner cartridge does not hinder the movement of the
gears in the drive train.
3. Check the main motor cable to make sure that it is seated correctly.
4. If the error persists, replace the motor, and then replace the dc controller, if
necessary.
Error 59.0 A motor error
59.X PRINTER ERRORA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor
3helpful
5answers
Error code E000002-0000
dispite the error, you should be able to enter the service mode.
Procedure for service mode is:
- press * ( additional functions - user mode )
- press 2
- press 8
Then choose COPIER, then under FUNCTION screen is CLEAR.
But you only can try to clear the error like E000, E001, E002 and E003.
Wich error code is apearing on display?
Here is some examples of error code:
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If nothing of these helps, send more specific description of problem.
Hope it helps
How do i fix a 59.90 error?
PRINTER ERROR A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error 1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor’s cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Top Roland Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
