Based on the documentation for the KX-T76XX phones, you can cancel the Call Forwarding by picking up the handset of your KX-T7630. Then press the FWD/DND button. Next press 0 to cancel all call forwarding. See page 17 of the manual here: https://www.ask-tsc.com/pdf/KX-T76xx.pdf . (You can also select to cancel call forwarding for external or internal incoming calls separately, if needed.)
If pressing 0 does not work, did you lock the extension? See page 18 for information on unlocking the extension. If that fails, contact your phone system administration. As far as I know, there is no global reset option available to users of an extension.
You can transfer a call between units, but you cannot forward to a different phone number. Page 48 of the manual details this: http://service.us.panasonic.com/OPERMANPDF/KXTG2357.PDF
Assuming your telephone service provider offers the call forwarding service, yes. The procedure varies from company to company, but often you dial *72 from the landline, then the number to which you want the calls forwarded. That phone will then ring, and you must answer the call to confirm. To cancel the call forwarding, dial *73 from the landline.
If this doesn't work, contact your telephone service provider for their instructions regarding call forwarding.
Hello,still having the same problem?I can remotely configure and cancel call forward and configure your system as you want it.Contact me for help. Mail me: [email protected] Make the subject be PANASONIC PBX
The simple answer is on the intercom dial *7102 9 number #. That forwards all calls outside. However, outside line and trunk-to-trunk programming has to be programmed into the system.
There are other conditions located in the Operating Manual under Call Forward. In mine, it's on page 71.
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Call forwarding isn't a "feature" on a telephone. You have call transfer to another handset, probably described in your manual, or Central Office call forwarding, the standard CF that works without the TG6500. You set that by following the CF instructions provided by your dial tone provider, usually a sequence that starts with 72#.
