Panasonic CT-27D12D 27" TV Logo
Anonymous Posted on Dec 01, 2008
Panasonic TV-Sound but no picture.
I get a straight colored line across the middle of my TV screen when I turn it on. It has normal sound but no picture. It did this a couple of weeks ago but after turning off for awhile it return to a normal picture. Now it is displaying the line with no picture and does not show any sign of going back to normal. If channel is changed the line will go away but the picture remains black.
Any ideas or toss it??
AMJAD HUSSAIN
Level 3:
  • Panasonic Master 586 Answers
  • Posted on Dec 01, 2008
AMJAD HUSSAIN
Panasonic Master
Level 3:
Answers
586
Questions
Helped
206032
Points
1533
    According to the symptoms, There is a problem in vertical out section.Just check it there must be a capacitor that has been burst or leak.And second one reason could be the malfunctioning of vertical IC.Which is also in the vertical section.
Thanks for using fixya.
My Panasonic HDTV has sound but no picture
I have a question : Is the line a faint band top to bottom towards the middle or to the right of the screen?
This was a fairly common problem if you can confirm it?
1helpful
2answers
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
*Screen Looks 3-D
*Colors wont align
Color band lines scrolling across my screen
That sound like your picture tube is doing. Also if you have any speaker near the tv it will effect it because of the magent.
3answers
When turned on only gets a straight line of color in middle of screen
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
1helpful
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
