20 Most Recent
Panasonic PT-51HX42 51" Rear Projection Television Questions & Answers
My Akita TV cant turn on ?
i have a akita rear projection tv n it's not working,where i purchase tv from n they say part is not available any more from supplier..i have spent thousands of dollars buying it n just sitting in my home,please wat can i do now n if there's any part for tv anywhere...
4/9/2013 1:35:02 AM •
Panasonic...
Answered
on Apr 09, 2013
I have a Panasonic HDTV Projection Monitor model
Three blinks is short protection in this model.
98% chance one of the protect resistors around the two STK-392-110 convergence chips is bad.
Good news here----total parts cost would be under 25 dollars on EBAY. I use a seller there.
I also have start to finish, step by step instructions for this repair in this set.
They tell you everything you will need and how to do the repair.
Let me know if you want help or the instructions--I can tell you how to look to see if the protect resistors are bad.
This is a very common problem and I have fixed hundreds of these sets with this problem.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
If you need more help or want the instructions let me know, we will find a way to get them to you for free.
SD TECH
9/10/2011 10:03:43 PM •
Panasonic...
Answered
on Sep 10, 2011
Having green and pink lines on the bottom and
It sounds like your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
8/27/2011 3:02:35 AM •
Panasonic...
Answered
on Aug 27, 2011
RED LINE LOOKS LIKE A
This looks like you have a convergence problem, very common.
I have start to finish step by step instructions for this repair in this set, they tell you everything you will need and HOW to do the repair.
If you can use a screwdriver and either you or someone you know can solder, repair will cost under 25 dollars in parts and take a hour or so to do and I will be available to assist you if you need help.
Before you rate this solution let me know if photos I attach look anything like your problem and if you have questions make a comment here.
SD TECH
no two sets will look exactly the same but you should be able to tell if your set has this type of problem.
7/12/2011 11:24:46 PM •
Panasonic...
Answered
on Jul 12, 2011
I have a panasonic pt-47wx42 projection monitor.
The 3 blink error is caused by failed convergence ICs and the six 2.2 ohm resistors. Installing the convergence repair kit for your model should solve the issue. The kit is available from
www.tvrepairworld.com the kit contains the 2 ICs with heat sink paste, the 6 resistors and the cd with instructions
7/11/2011 1:11:34 PM •
Panasonic...
Answered
on Jul 11, 2011
PANASONIC HDTV PROJECTION MONITOR MDL
The blinks are an error code - an indication on which is the part or the board that failed, not something to do with the settings. That can't be fixed with remote commands the tv will have to be opened and the faulty part/board replaced. You must count the blinks and post them here for a more precise diagnostic.
6/29/2011 8:54:02 PM •
Panasonic...
Answered
on Jun 29, 2011
My Panasonic tv just turned
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from
www.TvRepairKits.com Common Problem #1) Convergence has gone outProjection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
- Screen looks 3D
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
- TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
1/28/2011 6:33:37 AM •
Panasonic...
Answered
on Jan 28, 2011
Panasonic Cinema Vision power light
5 blinks indicates that the micro-processor IC on the DG board has failed. A component level repair is usually not possible in cases like this and the board has to be replaced to resolve the problem. Board costs about 200-300$. Let me know if you wish to replace it yourself .
1/17/2011 4:45:47 AM •
Panasonic...
Answered
on Jan 17, 2011
51"panasonic pt-51hx42....colors are seperating..lower picture
This kind of distorted picture comes when tv got problem in convergence output section and mostly convergence output chips got bad that need to be replaced to solve the issue.
Chips replacement requires soldering work in tv circuit board and local tv repairman will do this job fr you if you have no prior experience.
Let me know if you have additional question.
Thanks.
12/5/2010 3:32:42 PM •
Panasonic...
Answered
on Dec 05, 2010
Panasonic PT51HX41E 51" PROJECTION TV is doing the
There's a fault in the high tension module - one of the tubes is having an abnormal power draw that causes the high tension module to overstress, that in turn activates the autoprotection of the power source, that shuts the tv down.
The tv must be opened and tested to identify the failed part/tube. This is a job for someone with a lot of experience, otherwise a bad move can be fatal - there are over 25,000 volts there. Time to call a repairman.
10/8/2010 4:33:40 PM •
Panasonic...
Answered
on Oct 08, 2010
