HP LaserJet P2055d Printer Logo
Posted on Jun 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This software cannot be installed using the run as...
Florin
Level 3:
  • Master 733 Answers
  • Posted on Jun 12, 2012
Florin
Master
Level 3:
Answers
733
Questions
0
Helped
166572
Points
1640
first instal the software normaly if the software does not instal then start->run->cmd->run as:administrator ....password.write the path in the console then you can instal.
Put me on ask.com
Probably 'malware' (installed by software you wanted to have)
when some software is installed, 'free' software is also installed, Like toolbars and security software. They always run in the background, or when a browser is opened. Then they 'maintain' settings (I.e. search page & home page settings).
you can:
-disable toolbars in browser (that you don't want/use)
-diable/uninstall/remove software/features that you don't use
("always run" / "auto start")
-check your AV: McAfee/AVG/Norton. They also maintain your
search/home address settings.
if you notice new icons by the clock (that you don't need/use) remove/disable/uninstall the problem program.
Windows xp will not install my hp officejet 7310 all-in-one printer after i uninstallit? i keep getting a 1603 error or can't remove the old webreg?
If problems arise while installing or uninstalling the software, download this removal utility to uninstall the HP All-in-One software before attempting software reinstallation. IMPORTANT NOTE:
This utility removes only version 4.2.0 of the driver.
Running the removal utility may remove the drivers and software for other HP printing, scanning or digital imaging products.
This utility works in stages. The first time the utility is used, it runs at level one. The next time the utility is used, it runs at level two. There are four levels. The effects of each level are shown in the table below.
Uninstaller level Description 1 Removes the Windows device discovery (Plug and Play) entries from the Windows registry. After running level 1, connect the USB cable to the all-in-one and let Windows try to discover the device again. 2 Performs Level 1 and removes the software drivers. After running level 2, run the all-in-one installer and use the "Add a new device" option to attempt to reinstall the all-in-one again. 3 Performs Levels 1 and 2 and removes the HP Photo and Imaging software. You must completely reinstall the all-in-one software after running level 3. 4 Performs Levels 1, 2 and 3, and removes HP Software Update. You must completely reinstall the all-in-one software after running level 4. Installation instructions:
  1. Click the Download now button.
  2. When prompted, choose Open or Run to start the download and run the installer.
  3. Follow the onscreen instructions.
Details and specifications File name: s.gif gr_uninst.exe [1/1, 866.52k] Released: s.gif 2005-01-11 Version: s.gif 4.2.1 Compatibility: s.gif Microsoft Windows XP, Microsoft Windows 2000
This used to work perfectly on windows XP. I now have windows 7 & after downloading the Photo Explosion 2.0, it won't open & the programme just freezes. Help.
Downloading means you retrive any files and save to your PC/Laptop from any web source!
Installing means you install any software/programs to run on your PC/Laptop.
As for your software "Photo Explosion 2.0" could not run on Win 7 due to software "Compatibility Issues".
You can try, using "Win 7 compatibility mode" installing older software read this LINK
NOTE**
"There is no guarantees older software will work using Win 7 compatibility mode!"
Hope it helps.
Just loaded my vx-1000 and skype is saying this camera it not compatible with skype. can i fix this prob or have i wasted my money buying this cam! PLEASE HELP!
Skype is very particular about webcams using the latest drivers. If you installed the software using a CD the chances are the software is out of date.
Visit the Microsoft hardware support page
http://www.microsoft.com/hardware/download/download.aspx?category=ICE&type=LifeCam&sku=68A-00001
Fill in the details and click 'GO'
Aquaint yourself with the information available by clicking on the link:-
"Microsoft LifeCam Readme and Troubleshooting Information"
All the information you require should be found here, Including the latest software to download and Customer Support
Check out any additional software you have to download if you are running Vista or Windows 7
Procedure to install software from the website:-
Close all programs while uninstalling - downloading and uploading software
Disconnect your webcam
Uninstall the current webcam software on your computer
Restart computer
Download the Installation package from Microsoft
Run the installer and choose your options when prompted
Connect your webcam when prompted.
Once you have your webcam installed you can configure it to the chat program of your choice.
When using Skype do not run your webcam using the Lifecam software but let Skype have full control
4helpful
My computer do not accept the cd to install the software for sdr-h40 hdd camcorder, i get a message saying do not support the software
What OS is the computer running? The software isn't guaranteed to work with 64-bit Windows. (Windows 2000 through Vista are tested. Win 7 is an untested OS)
If you have Win7, you can try running the software in the compatibility mode. Right click on the Installer (.exe) and choose Properties. Click on the Compatibility Tab and check the box for Run this program in compatibility mode and use the drop down menu to select Vista or XP. Then right click again on the installer and choose Run as Administrator.
Another option is to run the software in a virtual computer running a supported OS. Win7 Pro and Ultimate support the XP mode which needs two programs downloaded and installed from Microsoft. Otherwise you need a licensed version of the OS to install in the virtualization program. Then install the camera software inside the virtual computer (as if it was the only computer).
I hope this helps.
(also note that the software does not run on some dual boot systems and may not run properly on multi-CPU systems. Updated software/drivers do not seem to be available on the Panasonic support site.)
Message no lexmark X9575 fax printer installed
Hi. Try to use and install the software again using the installation cd. When it runs, it should pop up the window with 3 options: Install a printer, Update/Upgrade, or Install additional softwares. Choose install additional softwares. In the next window, place a check mark in Fax solutions. Then, continue and finish the installation. If you don't have the cd, software can be downloaded by going to this link to the Lexmark website. http://bit.ly/d9TDnb . Download the compatible driver for your computer. Run the installation. Hope this helps.
I am facing problem with office 2003. whenever we run our official software.durin run that software office setup runs.what is the reason behind this
Uninstall and Reinstall Office 2003 as an administrator. Make sure you leave the setup files on the computer with the office installer prompts you. Then run office updates repeatedly until there are no more updates available.
You software is most likely using a feature of Office 2003 that is not installed and it is trying to install it on 1st use. Trying a complete install may fix this problem as well.
How to install kodak file DcPtp.sys ? I installed the software correctly, and once booting up my camera to it it tells me it needs this file? I can't find this file on the installation disk at all. HELP!!
Perform a clean installation:
1) uninstall the current kodak software from your OS
2) run the clear utility
www.kodak.com/go/clear
3) run disk clean up using default selections
4) reinstall the software again using the latest version www.kodak.com/go/easysharesw
1helpful
2answers
This software cannot be installed using the 'run as ...' command
there's always an administrator (even if it's the one and only user).
what version of windows? (I'm assuming windows).
if Vista you can try to run the installer as administrator (find the install program, right-click, choose run as administrator).
Install MS office home and student 2007
Reboot
Shut down any active protection software such any antivirus, antispyware, antitrojan, or registry monitoring software.
Try to Unistall by using the install disk. It should detect a previous installation and ask if you want to Install, Repair, or Uninstall.
If that fails, download and run CCleaner - Use the Cleaner and Regisrty modules default settings
http://www.ccleaner.com/
Reboot, and shut down active protection software.
Download and run Windows Installer CleanUp Utility.
http://support.microsoft.com/KB/290301
Remove the applicable entries.
Reinstall
Hope this helps - good luck!
k24674
Grand Canyon Tech
Grand Canyon Tech
