Toshiba CT-90157 Remote Control Logo
Posted on Sep 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The Cap/Text button works but it makes no difference on my tv
Hi, I've been using the Caption to have the txt on my tv for a while now.
Its been 2 days the txt doesnt work anymore!!!! It just stopped working! I could see the button changing to Caption 1 caption 2 or text 1 or text 2 but nothing happens!!!
I hope u could help me with this cause i have a deaf child who reads to understand!
thank you
Sandra D.
Steve F
Level 3:
  • Master 1,361 Answers
  • Posted on Sep 04, 2017
Steve F
Master
Level 3:
Answers
1361
Questions
Helped
567600
Points
3788
Try new batteries in the remote and confirm that the settings are correct and that you haven't accidently selected no caption option.
5 Related Answers
Dewayne Turner
  • 87 Answers
  • Posted on Sep 28, 2007
SOURCE: lockup/crashes
There is no part in this set called a text board. I suspect the person that gave you this information meant the wow board. it is a plug in board that is near the far right of the chassis as you face the back and is about 2" by 4". if you remove this board the and it is the cause of the problem the set will work but will have no sound.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
A
Anonymous
  • Posted on May 28, 2008
SOURCE: closed captions
Closed Caption may only come on when you have the television muted.
Anonymous
  • Posted on Jan 15, 2009
SOURCE: Turning Closed Caption "ON"
the manual for the tv is available at http://www.tacp.toshiba.com/tacpassets-images/models/MW24FM1/docs/MW24FM1_om_e.pdf
Anonymous
  • 103 Answers
  • Posted on Apr 13, 2010
SOURCE: can't find closed caption
I believe page #48 on this link will help, though I am unsure of the type of tv you have. I can only say that I hope this helps. If not, you could try to google your tv and see if you can find an online manual that tells you how to turn on the CC feature. Good luck! Sincerely, Der Strom
Chi Chu
  • 8457 Answers
  • Posted on Jul 09, 2011
SOURCE: How do I remove the closed caption or dialoge text
U have the tv original remote wright?Yes,look at the tv remote control,look for a button that said CC,push that CC button a few times make sure all CC1,2,3..all to off closed captioning should stop.No CC button on the remote.Go into the tv main nenu look for functions like Text 1,2,3.. and closed captioning 1,2,3... turn it all to off will fix the problems also.
Testimonial: "Thank you for your help. It worked. What a relief. "
Captation on TV screen can't get it off
Hello
To choose a Captions or Text setting, press "TV/CAP/TEXT". Each press brigs up a different settings. your closed-caption?text options are:
CAPTION CH1, CAPTION CH2, TEXT CH1 and TEXT CH2.
Note: Not all programmes carry closed captions or Text. If captions are available, they will probably appear on 'CAPTION CH1'
Press "TV/CAPTION/TEXT' button on the remote control repeatedly to On and Off the caption function.
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
1helpful
Does the toshiba 27a44 have closed captioning?
Hello
You have two options with closed caption feature.
Captions of Text
A caption is a printed version of a dialogue narration and/or sound effects of a programme. Text is information not related to the programme that appears on half of the TV screen when available.
To view Caption or Text
[1] Select the desired programme. Closed captioned programme are usually marked in your local TV listing as "CC"
[2] Press CAPTION/TEXT repeatedly to select caption or text mode.
[3] Press 1/2 to select the caption or text channel.
[4] To turn to off the closed caption feature, press CAP/TEXT repeatedly until captions or text no longer display 0n-screen.
Ok.
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
6helpful
Dark shaded square area in center of tv picture - how do I get rid of it? I am at mothers and she has what looks like a 36 inch tabletop JVC tube tv probably about 10 plus years old. not able to remove tv...
I have heard complaints from some of my customers, “There is a black/gray box on my television, but I can still see the picture around the edges”. This happens to all of us and is a common symptom and can be fixed very easily. If you have a black/grey box in the picture, on the older sets they would be perfectly centered on the screen, but, on some of the newer sets the black/grey box can be in different places and can be different sizes on different sets.
Most likely the Text mode is on in the Closed Caption menu.
The way you can test if it is in Closed Caption Text mode, when you change the channels, the black/ gray box will not appear right away but it will take some time to show back up. This is a very good indication that the Closed Caption “Text” mode is turned on for your television. It just needs to be turned off.
To turn off the closed caption go into your menu and turn off closed caption (CC). This will vary from manufacture to manufacture; it should be in the options menu.
I have seen on some sets like Mitsubishi puts it under the Video adjustments button. So you may have to look around for it.
You may even have a CC button on your remote, which will make it much easier. Just press the CC button until the display indicates that CC it is off.
I hope that this tip helps you and that you enjoy your televisions for years to come.
Thanks for using FixYa
asnowman
3helpful
Cannot get closed caption
To view captions or text:
1. Select the desired program. Closed captioned programs are
usually marked in your local TV listing as “CC.”
2. Press CAP/TEXT on the remote repeatedly to select caption or text mode.
3. Press 1/2 on remote to select the caption or text channel.
4. To turn off the closed caption feature, press CAP/TEXT
repeatedly until captions or text no longer display on-screen. I hope this helps. Thanks for using Fixya. Good luck
How do I turn off spanish closed caption?
the close caption feature is different than the language in the menu.
Try to find the close caption feature in the menu and get it off. Now if she hit a button then chances are you find some button with that description in the remote control (close caption or text) make sure is off.
Cannot get the closed caption off
Use the TV/CAP/TEXT button on the remote.
2answers
Black box on tv
Use the TV/CAP/TEXT button on the remote to turn off the text box function of the closed caption decoder.
52helpful
12answers
Black box in the center of screen
go to costumer menu and turn off closed caption function
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
