20 Most Recent
Orion TVDVD091 9 in. TV/DVD Combo Questions & Answers
No sound
If sound when a vcr is connected the set is ok as far as sound goes--something is not connected or right with the settings in the menu or if you have a headphone jack built into the set it may be the issue.Combos are like this--one part does not work and it becomes useless.The headphone jack if it has one is your best hope--supposed to cut audio off when a jack is inserted but the jacks on the rear or front bypass that.
Hello, we have an Orion
You should be able to do a channel search and come across the inputs either at the upper end or the lower end of the channel search. Using the channels on the TV itself, not cable or satellite, scroll through the channels until the desired input is found. Once on the desired input open the DVD player and insert a DVD and close the drawer. The DVD should start to play automatically. When it gets to the place on the DVD to actually "play movie" press the select/enter button on the remote. As for the replacement remote I would get a universal remote. They are far fairer in price than an original replacement remote and every bit as reliable. Just make sure to take the model of your TV/DVD player with you to make sure the remote you purchase is compatible. You probably need to go no further than your local hardware store or department store. Save on the shipping too. However if you are set on getting the original remote here is a place
http://www.orion.newremotecontrol.com/catalog_item.php?catnum=076R0DT090 they also sell a few generic remotes for a few dollars less.
Regards,
Tony
I have an Orion TV/DVD combo Model # TVDVD091A and
Most RCA and GE universal remotes can be programmed to work with your equipment. Walmart has one for less than $8 that works with most units, and also works with DTV tuners. You may have to program the DVD and the TV as two separate buttons
Black box on tv
Use the TV/CAP/TEXT button on the remote to turn off the text box function of the closed caption decoder.
Can I hook a genie Wi-Fi camera up to this TV, ORION MODEL NO:TVDVD092
It's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. In general, most modern TVs have built-in Wi-Fi connectivity and support for applications like Netflix and Hulu, which allow you to stream video from the internet directly to your TV. However, not all TVs support all types of Wi-Fi cameras, and some cameras may require additional hardware or software in order to be used with a TV.
In order to connect a Wi-Fi security camera to your TV, you will need to check the specifications and compatibility of both the camera and the TV. If your TV has built-in Wi-Fi and support for streaming applications, it may be possible to connect the camera directly to the TV using the Wi-Fi network. Alternatively, you may be able to connect the camera to a computer or mobile device and then use an HDMI cable to connect the computer or mobile device to the TV.
In summary, it's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. It's best to check the specifications and compatibility of both the camera and the TV in order to determine the best way to connect them.
Can a wifi geeni camera be set up to my ORION MODEL NO:: TVDVD092
It is not possible to directly connect a Wi-Fi Geeni camera to an Orion TV model number TVDVD092. The Orion TV model you have mentioned is a television set that is not capable of connecting to a Wi-Fi network or functioning as a Wi-Fi network device. In order to use a Wi-Fi Geeni camera, you would need a device that is capable of connecting to a Wi-Fi network, such as a smartphone, tablet, or computer. You can then use the Geeni app on that device to set up and control the camera.
