On this website (link below) you finde fuse box for Ranault Kangoo
Renault Kangoo mk1 1996 2006 fuse box diagram Auto Genius
SOURCE: Renault Kangoo starting
Had a look at the fuse (15Amp) that controls the door-locks and the imobiliser?
/H
SOURCE: replace cv boot on a renault kangoo
Did one today, assuming drive shaft removed take off large clip from inner boot slide back joint socket comes away leaving the knuckle joint on the shaft remove 19mm circlip and tap knuckle off spline this allows outer boot to come back - easy enough. Not much tubber to secure new clip over boot though especially with all the grease.
SOURCE: help, need the security code for renault kangoo van
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also confirm the MAKE of CAR it is fitted into.
SOURCE: renault kangoo indicators and hazard lights have
Most common cause is a failed indicator relay. Just swap it with a known good one to confirm whether it's faulty but ensure it's correctly rated for your Kangoo.
After that, the next most common causes are more expensive: the indicator switch and the hazard light switch.
