Video works when connected directly from DVD or Sat Receiver using HDMI. When using the HDMI through the Onkyo unit, I get the sound but no video. Only HDMI Cables are used as per the wiring diagram. The setup screens do work and they show the default HDMI input setup. I have the HDMI cables connected as per this default set up.
Still doesn't work.
Is there some HDMI output enable selection somewhere?
For me, it was the Monitor Out setting that had defaulted back to Component. I remembered to change the individual inputs to HDMI - but had forgotten to set the Monitor Out to be HDMI.
This has already been mentioned before - the problem is probably due to a mis-matched input assignment. Check that the input assignment for the device hasn't been set at 'Componemt'; best is to leave it at '---' or set it to 'HDMI' if it is actually connected thru HDMI to the Receiver. All other input connections (composite or svideo) are automatically upconverted to HDMI by the Receiver. This should solve your problem. Good Luck!
Try checking the input assignment section and go to Component Video Input. Make sure DVD and CBL/SAT has" -----" on them to prevent conflict. Hope this helps. ^_^
I have the exact same problem. Only sound and no video when using HDMI. If the individual components are hooked directly to the tv via HDMI, I get video. I tried connecting everything via component cables and still no video ( yes I changed the input settings).
Onkyo support (if they can be called that) told me to return it to the place of purchase. They really didn't ask much or suggest anything. It makes me think that they know there is a problem with the unit.
I was able to get HDMI to work initially; after switching input sources, the HDMI out no longer workes, even though there is only one HDMI out that was connected to the TV from the receiver.
Help. We just used all HDMI cables and plugged in the new receiver with our Sony HDTV, Sat, and Blue Ray Disc. We are unable to get the tv screen. Can someone give us some advice
Same issue on mine where I hear sound but it produces no picture through my projector which was the whole reason I bought this receiver. has anyone come up with a solution besides returning it as I ordered over New Egg??
Yes, I have the same problem: sound but no video on my Onkyo RX-SR606. It all worked perfectly since last June. The problem only started a couple of days ago. Everything worked fine in the evening but not the next morning. I didn't do anything but shut the equipment off in the evening and back on in the morning.
I checked all input asignments. They are correct and the same as prior to the problem.
I also have the same problem. I checked my inputs and they are right. I have to repeatly turn off my reciever to finally get it to show on the Tv
Problem is, if you can't get video out to work then how can you check to see if there is a mismatched input assignment?
I have the same problem. My set worked fine for 2 months and suddenly it stopped working. I get audio output but no video. The home theater box is connected to the TV using the HDMI out. I have checked all input assignments, they all look fine. I do not get the display even in the reciver setup mode! Please help.
HDMI output works only on the first input source during power up.
If you switch input sources (from cable to dvd), the HDMI output does not put out a video signal and the audio output is intermittent, working only for a second every 20 seconds. Is this Receiver a lemon?
Never worked, this problem is most fustrating. I am so disappointed. I would not recommend this product to anyone.
Try pressing and holding the display button on the front panel of your receiver, this should give you an idea if the receiver is receiving and transmitting video signals. please post what you see when you do it...
