HTC Hero Smartphone Logo
Posted on May 31, 2012
Rosie Utility has stopped working unexpectedly. None of widgets work. How do I get it working properly?
Dashlane desktop app quit unexpectedly on Macbook Air?
Dear friend,
Try to Repair Permissions on your Mac.
Go to Applications, Utilities, Disk Utility, Fist Aid, select your partition under your hard drive, and click Repair disk Permissions.
Stopped unexpectedly
see that keyboard software is updated or reinstall software if also not worked contact nearest help center
1helpful
Blue screen error STOP: c000021a {Fatal System Error} The windows logon process System process terminated unexpectedly with status of 0x0000005 ( 0x00000000 0x00000000). The system has been shut down.
It appears that your Windows Registry is corrupted. You can try to use a Registry repair utility like CCleane to fix it. If that doesn't work you will have to reload Windows OS (Operating System). For more info no this error code Google "c000021a".
2answers
IPhone camera stopped working
My iPhone camera stopped working.i press the cam widget and the shutter appears closed.
11helpful
4answers
Touchflo (process com.htc.launcher) has stopped unexplectedlu
All i did was take out my SD card and wait 15 seconds then put it back in the phone. I did not see the process com.htc.launcher error anymore.
Nero Vision 4 refusing to burn to DVD (Memorex DVD Burner)
if its having problems writing the lead in, it,s possible that the devices drivers are corrupt or incorrectly installed. to resolve this re-install nero, or better still upgrade to a newer version of nero.
also check that your media/ blank dvds are compatable. some writers support DVD-R But not +R.
if none of the above works, go into the device manager, and uninstall the DVD drive, reboot the computer, and re-install it. Other related problems are usually atapi or couffin drivers.
Mike @ compurepair.
I have an HP Photosmart Premium C3009 all-in-one printer. Sometimes it refuses to print with a message that says: The process stopped unexpectedly with status 1. I've looked in the manual and find no...
I also experienced the "process 'mdns' stopped unexpectedly with Status 1" message a few days ago with my new HP 7250, and found two solutions. Here are a couple of potential cures:
I downloaded the shareware program 'Printer Setup Repair', then ran their 'Reset and Backup' routine. Restarted, and bingo! Printing was successful. But trying to run either the HP scan software or the HP Ink Widget from Dashboard were not so successful. Got a 'Scanner not found' message. I then went to the printer, tried doing a manual scan there, sending the scan to my PowerBook. Once again, bingo. The scan was sent to my computer, and now the HP software could see the printer. I've since restarted both my computer and the printer several times; printing and scanning are working fine.
Now the second way to fix the problem. It's kind of hokey, but it seems to work, and is what led me to the The process 'mdns' stopped unexpectedly" with Status 1" problem in the first place. What you do is just add an ethernet router, that one you have lying around the house somewhere, between your DSL or cable modem and your Airport modem. Huh?
Here's the deal: when I first bought my HP multifunction printer, my wireless setup was this: Cable modem>Xsense ethernet router>Airport extreme. Unpacked and hooked up the HP printer, and it all worked immediately, perfectly. Print, scan, check supply levels, all no problem. Way too easy. Then, about a week ago I realized that the Xsense ethernet router that I had in the chain was really superfluous, as we no longer use ethernet in the house; might as well eliminate that unnecessary link in the chain. So I changed my setup to a simple: Cable modem>Airport extreme. At this point printing stopped. Tried everything I could think of, no go. Always got the "process ' mdns' stopped unexpectedly with Status 1" message. Put the ethernet router back in the chain, printing/scanning went perfectly. This made absolutely no sense to me, but it worked.
Left my setup with the extra router for a day or two until I remembered about the shareware program 'Printer Setup Repair', described above.
Before doing any of these steps it's probably a good idea to run Disk Permissions (I always run it before and after any installation), just to be sure you're authorized to be using the HP software.
My norton antivirus does not work properly
If there is anything iother then nortons( spyware antivirus etc..) Norton does not play well with others and the must all be uninstalled and nortone reinstalled
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
