The caps are marked with a plus and a minus side--polarity.
The caps are marked with values on them like 1,000 uf @ 10vdc= 1,000 micro farad at ten volts DC max working voltage.
Each has two leads as indicated above and must be unsoldered and replaced and then soldered back in.
Pretty straight forward stuff.
bad caps usually will be puffed up a little or a lot on top.
good on left and bad on right
Arrows point to real bad ones---see others also puffed and others perfectly flat on top.
