Manual service error
SOURCE: error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
SOURCE: Got a function code SC322 on lanier 5622 copier.
Most of the time the motor in the laser unit has gone bad.
The laser could also simply need cleaned.
SOURCE: Lanier 5622 says following output tray is full
Hello!
Why did you change the fotoconductor Unit???? This part of the machine is to create the image.
Your problem is in the tray. Meaby a broken switch. Take out the all tray and look inside to see if there is same obstruction.
If you do not see anything i advise you to call a Tech.
Dont waste more money if you dont know what your doing. This is the best advise i can give you.
See you!
