I need the network unlock code for my nokia 100 mobile phone and its on Tesco Network
Hello
would it be possible to provide me code to unlock nokia 100?
imei : 353674058302568
locked on O2 Germany
thanks.
I also have the same problem with nokia 100 prepaid o2 IMEI:355476050504375
I also have the same problem with nokia 100 prepaid o2 (germany) nokia 100 type rh-130 code 059L5W8 imei 351655/05/176440/1
Hello i have a nokia 100 locked on tesco imei no is 3591815511436. Many Thanks
HOW UNLOCK NETWORK CODE NOKIA 100
My Nokia 100 353269054510718
is locked to Bulgaria's Mobiltel company .
Can you give me unlock code :(
zdr az imam sastia vapros ti nameri li code i otkade ,mersi
My Nokia 100 with imei 353269053433714, code: 059N4C2. The phone is locked with unknown mobile company which I do not know. Is it possible to unlock it? I could not download the software from the links. Can you give me unlock code, please!? Thanks a lot for your help!
Nokia 100 with IMEI: 353269 05 343371 4, RH-130, code: 059N4C2. The phone is locked with unknown mobile company which I do not know. Is it possible to unlock it? I could not download the unlocking softwares from the links. Can you give me unlock code, please!? Thanks a lot for your help/reply in advance!
For nokia 100 unlock code (o2 germany)#pw+714 553 666 2+1#
IN REPLY TO marisler_d
pelase O2 Prepaid(Deutschalnd) IMEI:356320059500860
help me please.O2 Prepaid(Deutschalnd) nokia 100 type rh-130 code 059L5W8 imei 351655/05/176440/1
please help me: i have Unlocking Code nokia corporation model:100 type rh-130 code 059L5W8 imei 358955/05/021933/9
You can get the unlock code for your Nokia 100 from www.Superunlockcodes.com at low cost. Before that you can visit www.Mobileunlockguide.com This site provides free unlocking instruction guide. Which makes you understand unlocking process better.
Hi mate,
I need unlock code for nokia 100 on O2 UK
Imei: 356685057173336
thanks
My nokia 100 is lock to o2 germany imei 351940055974606
Please give me the unlock code. Thanks a lot in advance
Hi can you help me with nokia 100 sim unlock vodafone uk
IMEI: 351942051498283
My nokia 100 (355195051828605)is locked to germanycompany .
please help
Nokia all o2 uk and 3 uk and vodafone uk codes we can get
www.fusionunlocking.com
I need unlock code for nokia 100 O2-prepaid germany IMEI-359755047410127 ,CODE-059L5W8 somebody hehp me
Here have solution???
mein is nokia 100 O2 germany Imei: 358955050166134
plz helping!!
Hi I need fone unlocking model 100 wnt unlocked to any net work plz imei 353254/05/92106/0
Pelase O2 Prepaid(Deutschalnd) IMEI:356320059500860
Nokia 100 code 059R195 IMEI 355476/05/849744/0 HELP TO ME TO CODE ,,,,,,,,,,,,,,,,,
Hi there
Nokia 100
Imei 355502052210164
Virgin mobile UK
Thanks
Nokia 100 with <b> IMEI: 353269 05 343371 4, RH-130, code: 059N4C2.</b> The phone is locked with unknown mobile company which I do not know. Is it possible to unlock it? I could not download the unlocking softwares from the links. Can you give me unlock code, please!? Thanks a lot for your help/reply in advance!
SOURCE: need unlock code for lg ks360 mobile phone
Hi Friend,
Kindly follow the instructions in the below mentioned link and you can find by your own the unlock code
http://www.pb4kn.co.uk/ks360_unlocking.htm
If this is helpful and solved your problem kindly rate this
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: tesco samsung J700
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
SOURCE: Unlock code for Nokia 2720
To unlock your Nokia 2720 phone you will need to enter the code. This code is
just a calculation of IMEI number of your phone. To find your phones
IMEI number -type *#06# into your phone or look under the phone battery.
There are different online services that will calculate the unlock code for your IMEI number. I can recommend this one (cheap and reliable).
Click here to unlock your Nokia 2720.
Note: don't share your IMEI number on free forums like this.
SOURCE: i want to unlock my phone for free how do i do this please,
last week i unlocked my nokia 6300, http://www.unlock-free.com/ here so u may get assist just try
no network found jumper solution
Hello, Please, if it is possible. Nokia 100 IMEI: 355502052210164. Virgin mobile UK. Thank you
im sory bos her bos nokia 100 imei355476/05/849744/0 i ned boss code
code 059L5W8
plsss
Hi i have a nokia 100 that is locked to tesco the imei number is 35918055011436. I need an unlock code please.
Hi i have a nokia 100 that is locked to tesco the imei number is 354553050775410. I need an unlock code please.
35670701032191 nokia 100 type:RH-130 Code:059M0R1 vodafone spain pls unlock. thnx
