Razor MX500 Dirt Rocket Logo
jessie Posted on May 22, 2012
How to put the wiring back together
It was working and a plug broke and it had four wires and then another plug broke and im trying to put the wires back together
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
3624
Points
2006. Wires disconnected from underhood fuse box panel. How do I determine which wire connects where?
Not quite sure what you mean, did you break a wire harness loom that keeps all the wires bundled together or did you break an actual plug connector?
If you broke a loom clip them use black electrical tape to wrap the wires back together. If you broke a plug, go to the dealer and buy the new plug or harness. the new plug will have mew wires already attached and all you'll have to do is match color, cut, splice, solder, heat shrink and plug back in.
If you have another problem for some reason or another that I haven't hit on then I'd suggest going to your local parts stor or dealership and buy the repair manual for your car, turn to the electricl schematic section and follow your color codes from there..
Good Luck
4answers
My girlfriend had a friend start work on her 99 Buick LeSabre. He tore the intake cover off, all the fuel rail, the spark plug wires off, broke a plug in the block, pulled the alternator off, as well as a...
Hi Jason,here's a link on your fuel rail,Here's a link on your spark plugs,Why was he working on it to begin with?Here's how to put your alternator back on.Need more help,let me know.
I have a2000 pontiac grand am gt 6 cylinder my plug wires were put in the wrong firing order but now they are in the right order but when i stop and go to take off it dies or sputters and back fires w
Normally crossing the wires should not affect anything else if you did not try to drive the car.
If it still runs rough and backfires they could still be on the wrong plugs.
Its possible the coils or the ignition module the coils bolt to were damaged.
1helpful
How to bypass a lid switch on 26002010
You first un plug machine. Front panel has screws in the four corners. Trace lid switch to the back of panel. Cut the two wires and strip wire and put together , use **** connectors and put all back together. As you now, when washer is on high spin, make sure no kids open lids, as you just bypassed safety feature.
I have a 1998 ford escort zx2 four cylinder an i just put a stater on it an while i was putting it on i accidentally broke a red and yellow wire on the harness an i dont know were it suppose to go it split...
all wires in a cars harness are color coded so now carefully cut the tape back until you find the leads and then repair them. you will need to use wire connectors don't just twist them together. by the way those are the solenoid wires.
03 monte carlo ss power seat wont go down. how to fix?
i have a 2003 monte carlo and the wires came out of the plug under the seat. im trying to put them back in so my seat will be able to work. there are 12 wires that make up 6 connections. i need to know what wires go together. the wires are red with blue strip, red with green strip, red with white strip, yellow with blue strip, yellow with green strip, yellow with white strip, light green, green, peach, blue, light blue, and yellow.
Hello, Im trying to rewiremy transmission on a 92 GMC 3500 vandura box van. My don chewed the wiring that plugs into the transmission The plug has 11 wires coming out of it but some of them that he didnt...
Hello tnvolsfan32,
Use the FREE drawing available on the
BBB Industries site to trace out your wiring...
BBB Industries Premium Alternators Starters Power Steering Products
First put the wires together that
DO PERFECTLY MATCH... Then go
back to the drawing and find out what
DEVICE, CONNECTOR or PLUG got
disconnected or swallowed.
Generally wires DON'T CHANGE COLORS
in a wiring harness run... So you definitely
need to look for a LOGICAL EXPLANATION.
Registration is required... these are real
wiring documents...
Each time you return from a WIRING page
make sure you have not
defaulted back into TSBs...
(technical service bulletins)... While usually
quite useful... they don't begin to address any
WIRE-EATING-DOG problems...
If you get confused comment me back...
I can recommend some great tools to help
SPLICE everything back together
Tone Tracer being PRIMARY
Extech TG20 Wire Tracer and Tone Generator Amazon com
Helpful hint: wire must be ISOLATED to trace correctly
(pulled fuse or chewed through works).
Hope this helps
Carnac the Magnificent
Need help with epson pos
its not the relephone plug the 24 v wires sound about right i believe the telephone plug would be for credit/debit card sales via a built in modem and magnetic card reader hook up the wires first by stripping them back and electrical taping them together put drawer in and plug it in should work if not switch wires try again once it works either solder or use a **** conector or wire nut and tape to ensure it doesnt ground out
Top Razor Cycling Experts
ADMIN Eric
ADMIN Eric
vince
ADMIN Andrew
ADMIN Andrew
Are you a Razor Cycling Expert? Answer questions, earn points and help others
