Cameras Logo
Anonymous Posted on May 16, 2012
Unable to view photos i have taken, Screen says Read Error
After i have taken a photo i am unable to view it as the LCD screen shows a blue square 'running' around itself (like the Mac beach ball!). Sometimes it doesn't do that but says Read Error, instead.
Anonymous
Level 3:
  • Fuji Master 32,281 Answers
  • Posted on May 17, 2012
Anonymous
Fuji Master
Level 3:
Answers
32281
Questions
Helped
7913663
Points
102259
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
Testimonial: "Thanks Chris, that is an idea. I actually restored the factory settings on it, thanks to another suggestion from a friend, and everything seems to be back to normal. Thanks again."
5 Related Answers
Anonymous
  • Posted on Nov 26, 2009
SOURCE: My Nikon D40 LCD Screen doesn't show a live view
the d40 does not have live view. you would need to get a different camera.
Anonymous
  • 667 Answers
  • Posted on Jan 20, 2008
SOURCE: d70s lcd screen is black
The D70S is a SLR (single lens reflex). You cannot use the LCD for taking pictures like the small compact digital cameras. There is no way for the CCD sensor to have any image prior to taking since it is behind the mirror and the shutter is closed.
t00nz
CameraR
  • 4738 Answers
  • Posted on Nov 08, 2009
SOURCE: my canon sd10 digital camera lcd balnk/black bu
Had the same problem with my SD10. The switch in the AV port sometimes gets dirty or corroded, and tricks the camera into thinking that an AV plug is inserted. This will turn off the screen.
To fix it, repeatedly insert and remove an AV cable into the port several times. This may help break off any corrosion or dirt that may be holding this switch open.
Anonymous
  • 10594 Answers
  • Posted on Dec 23, 2009
SOURCE: lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Anonymous
  • 94 Answers
  • Posted on Jun 02, 2010
SOURCE: when i view my photos on my camera they come up with 'read error'
Sounds like the card is failing - try recovering the images with a free software package - Google will find you lots - then Format or discard the card. Format in the camera - NEVER format using a computer
12helpful
SONY DSC T33 SCREEN STOPPING SHOWING. CLICK SONY DSC T33 SCREEN STOPPING SHOWING. CLICK BUTTON,FLASH WORKS AND IT APPEARS TO TAKE A PHOTO BUT NOTHING SHOWS. ALL ISONY DSC T33 SCREEN STOPPING SHOWING. CLICK...
This is due to failure of ccd imager chip in your camera, replace ccd imager chip to get live view in lcd to take fresh pictures.
Let me know if you need ccd imager chip part number.
1helpful
When i view my photos on my camera they come up with 'read error'
I solve the problem of extreme reflection in the lcd screen.
I assume you're talking about pictures taken outside on a sunny day. All cameras are hard to see in bright light.
2helpful
Unable to actually see the photo in progress in the lcd!
I suppose you are referring to EOS XSi.
Hit the menu button
Go to the fifth menu, and choose the "Live View function settings"
On "Live Viwe shoot." select "Enable" option"
Go back to shooting modes.
The option works only with non automatic modes.
Hit the "SET" button each time you want to see the current picture in the screen, instead through the viewfinder.
Set to MF on the lens switch "AF-MF"
Please let me now if it works.
4answers
A95 LCD screen black and unable to take photos
Its common problem in canon cameras and I have solution. please let me know if you didn't find in chat.
My sony
I can fix your camera, it is not an easy thing to post because the post would be forever long....
$20 and it would be good as new.
FinePix A340....Flashing lines across LCD screen
I have the exact same problem !!! I wish someone would be able to help with this one !
1helpful
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
File error
I have seen this problem with generic SD memory cards so it could be a faulty memory stick.  Try to get a replacement.  If you want to try to recover the pictures you have taken, I suggest Zero Assumption Recovery (Google for it). Check to see if it is compatible with your camera before downloading.
Barry
Sep 17, 2007 • Cameras
2answers
Broken lcd screen
Sorry Douggie, you are havin a serious problem. your problem shows that there is no problem with its LCD screen itself but it is problem related with CCD sensor. Camera needs CCD replacement compulsaryly. So that no one can help you. It is advisable to go to Canon shop. thank you and good luck...
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
