2004 G-35 Sedan - took it to get inspected today, the center brake light (rear window) was not working so it failed. Is the problem possibly a fuse or is it most likely a bulb. Firestone wanted $170 to fix it - without really looking at it first. Need some help on where to start.
Took mine apart today and found my third brake lamp had some soldier that had cracked on positive and negative causing intermittent third brake operation. Email me and I will send you pictures [email protected] oh yeah my car was a 2003 g35 coupe. Don't know if they are all the same.
I had the same problem on both of my G35 cars. It seems the problem lays in the plug connector for the light itself. I just cut the plug off the light and hard wired it to the wiring harness. All is well now.
Sounds like the bulb change that first. joe
I have the same problem. I was told by my mechanic that it is a special bulb and the entire thing must be replaced to a tune of $200!
