Sony TAM-100 Telephone Answering Machine Logo
Anonymous Posted on May 07, 2012
How to record the answering message?
My recorded message was erased and a generic one is there. Possibly happened with power outtage
  • Anonymous May 08, 2012
    I don't have the manual.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Sony Master 102,366 Answers
  • Posted on May 07, 2012
Sony Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444099
Points
622693
Follow the instructions in the second column of the first page of the manual.
  • kakima May 08, 2012
    Click on the link I gave to get a copy of the manual.
Answering machine sounds like 3people are all talk Big at same time
Might not be erasing former messages and just recording new ones - Erase function may not be working. Try erasing all messages and see what happens.
2helpful
How do I record message as power outage erased it I do not have the manual for this.
Press and hold the ANNC/SKIP button. Record your message at the beep. Release ANNC/SKIP when done.
You may view the manual here.
4helpful
How do I access my messages when I am out of town. I have a Panasonic DECT 6.0 Thank you. ginny
Call your phone while you're away, and when your message starts to play enter your remote code. After that, you use the keypad on the phone to control message playback, record a new greeting, etc.
"DECT 6.0" is a generic term for the cordless phone technology, and not your phone model number. You'd find that on a label on the back or bottom of the base unit. Without a specific model I can't look for a manual and give details, but if you have the model listed you can download the manual from Panasonic here. It gives all the steps to set up your remote code and the commands to use. If you have a different model phone you can look for your manual at Panasonic's support page.
For the model listed above, the default remote code is 111. The list of remote commands is
Key Remote command
{1} Repeat message
(during playback)*1
{2} Skip message (during
playback)
{4} Play new messages
{5} Play all messages
{6} Play greeting message
{7} Record greeting
message
{9} Stop recording
Stop playback*2
Start voice guidance*3
{0} Turn answering system
off
{*}{4} Erase message
currently playing
{*}{5} Erase all messages
{*}{6} Erase greeting
message (during
greeting message
playback)
{*}{#} End remote operation
(or hang up)
Maybe this list works for your phone too.
3helpful
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
How do you set up the message for the answering machine? Lost the instructions that came with the unit. I know the phone has a menu, but not sure if this is where I would program the answering machine.
Greeting message
are greeted by a greeting message. You
can record your own greeting message
or use a prerecorded greeting
message.
message
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering device” i
{OK}
3 {V}/{^}: “Record greeting” i
{OK}
4 After the handset beeps, speak
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
Using a prerecorded greeting
message
prerecorded greeting message for
callers and ask them to leave
messages.
1helpful
2answers
Retrieve orginal factory greeting after being erased
Hello folks, I offer no guarantee on this but it worked for me.
1. record own greetings >menu>answering device> record greeting>then after recording own greetings press OK
2. Erase own greeting just recorded >menu>answe...device>erase messa...>erase greet...>Ok
3. Then try Menu> answering device>play greeting....voila. Prerecorded message plays.
Hope This helps.
Personal message not going out
Generic message mean the origional memo from manufacture? or the record message from caller far end? Try to power off and on again, record your personal anoucement one more time.
2helpful
The pre recorded message on the answering machine has been lost.
I read thru the manual. There is nothing bout recovery of factory messages. If you recorded your own, try deleting it. Or unplug the base from power and try a reset. This is from the manual. At the end, I gave you a link to the manual!
message
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
Help
sorry it sounds like the folder may be lost forever.once you pressed the record button, the recorder knew it as a new recording in that folder.look at it like a answering machine going out message. if you made a mistake,and you wanted to record a new message,the old message would be erased.if your folder was on a cassette recorder, you would have only erased those few seconds.
sorry
wg
Top Sony Lands Phones Experts
k24674
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
