Hi Mark.
Reversing the polarity:There are 3 wires on the Wig Wag Assembly. (reverse the wig-wag function) simply de-solder the 2 outer wires & swap their position & re-solder.I would seek a price for doing the job from an approved scooter repairer,unless you are comfortable doing the job yourself.I hope this has helped,Colin
SOURCE: need to change mobility scooter controls back to right handed
Open up the front shroud (unhook batteries first) and switch the wires going to the throttle pod, its just 2 thin wires and if they were switched already you will probably be able to switch them back. The throttle pod is what the thumb throttle lever is hooked up to.
SOURCE: little gem mobility scooter brake not working properly
The throttle part has slip round, a way to test this is to put hte buggy in reverse slightly and it shoud stop, meaning that how much the throttle has slipped round. Take the top cover off and there should be a allen screen on the throttle stem, undo and readjust.
SOURCE: have Invacare Auriga 4 scooter about 2yrs old Put
Hi. I have had a few scooters that have had this problem after sitting for a while. The brake lining is stuck to the body of the brake assembly. When the brake is energised by the controller, it can't release.
De-clutch the machine like you did, and try rocking the machine back and forth. If this doesn't work you might have to have a new brake assembly fitted.
The wheels turn in opposite directions, because the drive is through the differential unit in the rear axle. Even a car will do this if the driving axle is raised in the air.
I have also had a few cases of stuck motor brushes in these machines, but from your description, I would say it is the brake assembly.
Good luck. Neil.
Testimonial: "It was a frozen brake. I took the brake to pieces,a lot of little springs spacers indent springs and rollers jumped out. Cleaned all components and spent a few hours figuring it out for re assembly. Working fine now . Thanks for your prompt and accurate reply. PeterR"
SOURCE: Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
