Panasonic KX-TG2313 Cordless Phone Logo
Posted on Nov 19, 2008
Ringer not working
I turned it off by accident and need to have a ringer...Thank You
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
999
Points
On the base press the volume up [^] key. Repeat pressing to get higher volume. Press volume down [V] for reducing the volume. Press and hold volume down for two seconds to turn ringer off. On the handset, you can use the menu to turn ringer on and off.
3helpful
How do I turn the ringer back on on the Uniden dect 6.0
The procedure varies from phone to phone. Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
1helpful
The ringer on the phone is too loud. I cant work in my office using another line.....How do I turn off the sound of the ringer on the phones.
Welcome to FixYa!
How to adjust or turn off the ringer volume on your handset.
Thank you for using FixYa. Have a great day.
Jas247
1helpful
Can i turn down the base ringer (or turn off) on my vtech dect 6.0?
Welcome to FixYa!
The base ringer is dependent to your handset ringer. If you lower the volume or turn off the handset ringer, the base ringer will follow.
Have a great day.
Jas247
How do I turn the ringer back on?
Be sure you haven't pressed the mute button by accident. If so, press the mute button again to engage ringer.
VTECH CS5121 Need to turn off ringers on base and handheld
http://www.vtechphones.com/vtechui/support/manual.cfm?manualID=314062
I need to know how to turn off the ringer on my vtech phone
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download a copy of the manual.
2helpful
Need ringer turned back on .. radio shack 5.8GHz
Hit the up or down arrow keys several times. (either key will work) and the ringer will rotate through Ringer off - Ringer low - Ringer high... one set will be a steady ring, the other set will be a warble ring. This works on the phone made for RadioShack with 5.8 GHz on the front and Cat. No. 43-155 under the battery in the battery compartment.
2answers
Ringer turned off
Browsing through the menu should eventually show you the page for setting the ringer. Choose the menu by pressing the button, then jsut use the arrow key for stepping through it until you find the ringer menu item.
1helpful
I have a number of telephones (1927-1970) that work but do not ring and need instructions. Thank you.
If the phone has a dial tone, adjust the ringer loudness (this adjustment is on the bottom of some phones). Also check to see if there is a switch for turning off the ringer--and turn it on.
In some cases, you can't connect more than five phones to a given line or they won't ring properly. If this is your situation, you may have to disconnect one or more phones, or at least turn their ringers off.
I can't hear my ringer
may be there is a loose contact with the ringer speaker... or may be it s gone... just get the ringer speaker changed from nearest technician .....
may be due to accidents such has falling of the cell to the ground or falling into water has destroyed it or it is in miscontact....
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
