There are two possible fixes. This article provides the self-diagnostic
steps necessary to evaluate top-to-bottom streaks that appear when
copying or scanning. Important! This is seldom a scanner hardware failure. The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans. Printed or Scanned Page Illustration
Any user of an MFP or All-In-One printer experiencing the following symptoms: Think of it this way:
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem
Vertical lines; Auto document feeder scan anomaly; ADF scanning
problem; Scan issue; Scanner issue; Visible line; Streaks show on page;
solid line down the page; Top to bottom line; Smudge runs down the page;
Opaque line; Broken line; Bar all the way down the page
Solution
Overview
Who should consider this article?
ADF scan behavior
Suggested Diagnosis and Fix
Step
Action
Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
Perform a visual inspection for any of the following recurring culprits:
HINT:
Ink marks can be especially hard to see and almost translucent at first
sight. However, the image sensor (CCD) registers them as a mark.
Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris.
Inspect the underbelly or underside of the ADF for any marks or debris.
5
Perform another scan to see if cleaning the glass alleviated the issue.
6
Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7
This time, place an intentional mark on a blank sheet of
paper and take note of its location. Now place that sheet of paper in
the ADF and make a copy.
8
Evaluate the distance of the vertical line to the your mark.
9
Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If...
Then...
Vertical lines appear only when printing...
Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
Vertical lines appear when you lay the page on the flatbed...
Vertical lines appear on ADF-fed printed copies, but
they do not appear on scan-to-network [e-mail, FTP, folder (PC),
solutions]...
