20 Most Recent Lexmark International LEX90T9005 Inkjet Printer 905 Wireless- 150 Cap- 18.3in.X15.4in.X12.1in.- BK Questions & Answers
Scanner leaving black streaks
There are two possible fixes.Download the latest firmware update by CLICKING HEREThe following is provided by courtesy of Lexmark: Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
copyvertstreaks.jpg Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans. HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area. 2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears. Remember! Printing and scanning from the scanner flatbed work fine. 7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy. 8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
5/1/2012 7:41:45 PM • Lexmark... • Answered on May 01, 2012
Our Lexmark 6781-024 S/N 11THG84 - #1 & 2 green blinking light/nothing else works
The printer is in good working order if it displays the messages READY, BUSY, or POWER SAVER. Try the suggestions below if the beeping sounds persists.
The printer is indicating a "hardware failure" condition if it beeps THREE times, followed by a pause. The printer's display panel needs to display the precise fault message. Determine what the error message is trying to tell you and take the necessary action. Power off the printer and let it wait for a minute before turning it back on if you are unable to determine the precise fault situation from the panel. The printer will probably need repair if this issue persists. For more help, please get in touch with local authorised service providers or Lexmark Technical Support.
2/14/2023 1:49:39 AM • Lexmark... • Answered on Feb 14, 2023
Lexmark Printer tEcH sUpPoRT pHoNe [#@]-nUmBeR USA
Warning to FixYa readers - DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you. Please only ever use the support contacts from the official company website {edited by volunteer Expert}
11/13/2019 7:08:43 PM • Lexmark... • Answered on Nov 13, 2019
2answers
LEXMARK PRINTER toll Free pHoNe # {+1^8OOSCAMMER 69-} nUmBeR USA
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
11/9/2019 8:02:40 PM • Lexmark... • Answered on Nov 09, 2019
LEXMARK PRINTER tech suPpOrt pHoNe {+1~8OO8O3*1O69-} nUmBeR j USA
Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/9/2019 6:39:35 PM • Lexmark... • Answered on Nov 09, 2019
LEXMARK PRINTER tech suPpOrt pHoNe {+1_8OO8O3_1O69-} nUmBeR k USA
MUSTUZORK, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/9/2019 6:36:18 PM • Lexmark... • Answered on Nov 09, 2019
LEXMARK PRINTER tech suPpOrt pHoNe {+1^8OO8O3^1O69-} nUmBeR j USA
11/9/2019 6:35:50 PM • Lexmark... • Answered on Nov 09, 2019
Lexmark PRINTER tech suPpOrt pHoNe {+1_8OO8O31O69-} nUmBeR k USA
SILTAMIRDU, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/9/2019 6:35:36 PM • Lexmark... • Answered on Nov 09, 2019
Roadrunner Mail customer number +1855*.*536.*.5666 Roadrunner Mail Toll free Number PDYTEZK
11/9/2019 6:27:08 AM • Lexmark... • Answered on Nov 09, 2019
CUSTOMER HELPO HELPO?? WHAT??
11/9/2019 6:26:53 AM • Lexmark... • Answered on Nov 09, 2019
SUPPORT NUMBERO AND LETS NOT AND SAY WE DID OK??
DASHAYE, Your message does not qualify as a question or query for a problem, try somewhere else DO NOT MAKE THIS SITE WITH YOUR GARBAGE Take your GARBAGE to another Side Your message qualifies as SPAM
11/9/2019 6:26:44 AM • Lexmark... • Answered on Nov 09, 2019
2answers
THIS POST WAS WAY TOO LONG SO NOW ITS GONE...AS
11/9/2019 6:26:14 AM • Lexmark... • Answered on Nov 09, 2019
2answers
Amazon prime refund phone Number IS CLOSED
11/9/2019 6:25:17 AM • Lexmark... • Answered on Nov 09, 2019
SOLVE +1855*.*536.*.5666-Roadrunner Email customer support number
11/9/2019 6:25:05 AM • Lexmark... • Answered on Nov 09, 2019
2answers
Roadrunner Mail support phone number 1~855~536~5666 Roadrunner Mail Support Number KCDCLKW
FixYa Experts: Once you have reached a certain number of answers, then you can Edit and Delete these spam posts too, so they don't victimize unwary users. By my estimate, 4 of your fellow volunteer Experts are currently deleting 5000 or more spams per day, and it's not keeping up with the flood. Please help us out.
11/9/2019 6:13:04 AM • Lexmark... • Answered on Nov 09, 2019
2answers
Roadrunner Mail support number 1~8.55~5.36~56~66 Roadrunner Mail Contact nUMBER BABGHQR
11/9/2019 6:12:50 AM • Lexmark... • Answered on Nov 09, 2019
2answers
Roadrunner Mail phone Number O#1~855~536~5666 Roadrunner Mail protocol number TANCXLY
11/9/2019 6:12:37 AM • Lexmark... • Answered on Nov 09, 2019
2answers
DASHAYE??? REALLY LOL
11/9/2019 6:12:15 AM • Lexmark... • Answered on Nov 09, 2019
Lexmark Printer tech support phone~#~{+1^85522l~4867~}nUmBeR Texas
11/7/2019 6:02:38 AM • Lexmark... • Answered on Nov 07, 2019
Lexmark Printer tEcH sUpPoRT pHoNE{#}{1^85522l^4867~}nUmBeR Texas
11/7/2019 6:02:25 AM • Lexmark... • Answered on Nov 07, 2019
Lexmark International LEX90T9005 Inkjet Printer 905 Wireless- 150 Cap- 18.3in.X15.4in.X12.1in.- BK Logo
1 questions posted
Top Lexmark Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lexmark Computers & Internet
Most Popular Question
scanner leaving black streaks
  • Computers & Internet
