Washing Machines Logo
Luis Alberto Posted on Dec 12, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY WASHER WHIRLPOOL LA5430XTW0 AFTER THE WASHING CYCLE IS DONE IT DRAINS OK, BUT DOESNT SPIN, AFTER THAT IT ADVANCES TO THE RINSE CYCLE BUT DOESNT DO ANYTHING AFTERWARDS, IT DOESNT FILL THE TUB, IT DOES THIS IN ANY CYCLE, REGULAR, PERM PRESS OR DELICATE. ANY IDEAS WILL REALLY BE APPRECIATED, THANKS IN ADVANCE.~ LUIS
  • Luis Alberto
    Luis Alberto Apr 11, 2012
    COULD IT BE THE LID SWITCH BY ANY CHANCE.?? I'VE SEEING MANY WASHERS THAT IF THE LID TOP IS OPENED SOME MAY CONTINUE TO WASH BUT STOPS ON THE SPIN CYCLE TO PREVENT INJURIES.!!
NOEL
Level 3:
Top Expert:
  • Whirlpool Master 8,606 Answers
  • Posted on Dec 12, 2017
NOEL
Whirlpool Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322426
Points
68630
Hi Luis.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
What do you do when your washing machine wont drain? Steps
  1. Consult your troubleshooting manual. Most washers come with a troubleshooting manual. ...
  2. Check your drain hose. ...
  3. Run the rinse/spin cycle on your washer. ...
  4. Clean the pump. ...
  5. Turn the handle counter-clockwise to remove the screen. ...
  6. Remove everything from the screen and rinse it off. ...
  7. Run the rinse/spin cycle again
https://www.wikihow.com/Fix-a-Washer-That-Won%27t-Drain
5 Related Answers
Anonymous
  • 69 Answers
  • Posted on Sep 23, 2007
SOURCE: Admiral washer (LNC6748A80) does nothing during first spin cycle
Faulty timer ?
Anonymous
  • 131 Answers
  • Posted on Apr 01, 2008
SOURCE: Whirlpool Washer no spin cylcle
Motor coupler strikes again!
Anonymous
  • 3361 Answers
  • Posted on Mar 12, 2009
SOURCE: amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Anonymous
  • Posted on Jan 01, 2010
SOURCE: Washer won't do spin mode
Repair Clinic solved the problem for free and I'll be buying the part from them. Thank you!!
Anonymous
  • 215 Answers
  • Posted on Feb 11, 2010
SOURCE: whirlpool 4213632 wont drain water on perm press or delicate
check manual as this seems to be correct, Often called rinse hold or crease gaurd on many other machines
1helpful
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Won't finish the final spin
Post further comments for more information ....
Good Luck!!
Thanks
The washing machinge is not completing the complete cycle
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
1helpful
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
As washer was on final spin cycle it sounded like a belt came....
3helpful
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • 3helpful
    Whirlpool AWO3761 stuck mid-cycle
  • 2helpful
    2answers
    Stops on rinse cycle
    I had this exact same problem. Check and see if the screws to the door hinges are tight and if any are missing. I had one screw missing and it would not allow the door to be level and thus not be able to push the switch all the way down. This tells the washer the door is closed and if it is not closed it wont continue with the rinse cycle.
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
