take it back for a warranty exchange after you check that the thermostat setting is on steam
distilled water is recommended for irons
bottled water ( filtered water) and tap water is the same product and will have minerals and contaminates that affect irons
Please don't take Landsend advice, as it contadicts this whole "fixya" site! Let's keep it going by not giving in to this throw away world! Some people can't afford a $20 iron @ Wally's! All the solutions above (besides Landsend) are on it!! Your City water is still too, hard for these delicate, devices. Filtered, as Alan Serna mentioned, is the way to go!! Dump your water out of your iron, when not using-maintenance is key, for everything, even your families!! : ) Have a G8 day!
Yes, there is a "Solution" you could use in the reservoir to remove the crud. First of all, STOP using tap water. What you have is mineral deposits inside your iron from using tap water. Use ONLY steam distilled water. I usually find this at my grocery store. To clean out your iron, use white vinegar in your iron instead of water. This is to CLEAN the iron ONLY! Do NOT use to press cloths! And make sure the steam and/or water flow very clear (free from "sand", dirty water/steam or any other contaminates BEFORE using iron to press your cloths. You may need to flush the iron with water (remember, steam distilled ONLY) more than once to get all of the vinegar out. Hope this helps...
Common problem if you have the temperature or steam setting set too low (not enough heat/steam to vaporize water droplets or the unit is not up to full temp. I would have a clean towel alongside the iron to give a burst of steam prior to your first press...
1: Make sure there's enough water in the tank if the iron won't steam.
Fill
the tank up . 2:Check that the iron is set to a steam setting. Some
of the settings are
dry and won't create steam. 3:Set the temperature dial to the shaded
setting which represents steam.
You'll see a little dark cloud-type icon with raindrops as opposed to a
white cloud with a stripe through it. The dark cloud represents moisture
(steam), and the white cloud with the stripe through it represents no
steam. 4:Allow the iron to heat up for a while and to emit steam for a
couple of
minutes while pressing the extra-long burst button a few times. That
should get rid of any impurities which can cause blockages. Try this if
the iron hasn't been used for a while and steaming is intermittent. 5:Iron
horizontally. Steam is only generated when the iron is horizontal. 6:Use
the maximum steam setting when the iron is set to its maximum
temperature setting. 7:Let the iron get to a high temperature before
expecting steam. If the
soleplate isn't hot enough, the water won't turn to steam and will in
fact drip, spit or leak from the soleplate. Some Rowenta irons have an
anti-drip system, which will turn off the steam when ironing at a low
temperatures. Turn the temperature up, if needed.
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill
the tank up . 2:Check that the iron is set to a steam setting. Some of the settings are
dry and won't create steam. 3:Set the temperature dial to the shaded setting which represents steam.
steam. 4:Allow the iron to heat up for a while and to emit steam for a couple of
the iron hasn't been used for a while and steaming is intermittent. 5:Iron horizontally. Steam is only generated when the iron is horizontal. 6:Use the maximum steam setting when the iron is set to its maximum
temperature setting. 7:Let the iron get to a high temperature before expecting steam. If the
Hi, It is likely you have too much residual water in the iron or have mineral deposits from the tap water you have been using. Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
