When i turn ot on it boots up and everything but then the screen just freezes and says korg pa50. and i only got one sound coming out. no menu or anything lights dont light up either except 1
SOURCE: My Korg CX-3 Combo Organ
From the user manual troubleshooting: No sound • Are the other devices or headphones connected correctly? Check the connections. ........................................ (see p.6) • Is the power of your amp or mixer turned on? • Is the [MASTER LEVEL] knob raised? • Is the Global mode Group 4 "MIDI Local" parameter turned On? Check the setting of this parameter. • Are the bars of Drawbar 1 or 2 pulled out?
Pull out some of the bars.
Also check out this site and scroll down and do the "Factory reset" by holding down the buttons they say... AND please note that you have to hold them for a while during this.
SOURCE: Hi Iam using my
The styles on the PSR9000 are NOT available on the PA50. Any styles of the PSR9000 would only come from the audio generation and outputs of the PSR9000. The PSR9000 would have to be setup to the style independently as that cannot be controlled via MIDI from the PA50 controls.
SOURCE: Korg PA800 not booting up
I suspect you have aa pwer supply problem that is supplying low voltage to the unit. The display will light at low voltage but circuitry will not run when voltage is low.
not a sd.
