I have installed The Sims 3 on my mac but when I was trying to install Sims 3 World Adventures, a message appeared saying "The setup has detected that the regional install code for The Sims 3 is different than what this expansion requires. - This product requires The Sims 3 to have the same regional code in order to be installed" I bought The Sims 3 in Denmark (region 2) and World Adventures is from the US (region 1). Please help, how can I change the area code on The Sims 3 to be compatible with World Adventures??
You can try Leawo Blu-ray Player which is a region-free player. With it, you don't need to change the region codeDVD region code can be changed, but only for limited times. So before you change the DVD region code, you should think carefully because once you reach the max change time, you will not be able to change DVD region code again.
Wondering if you need to change your ip address .
to denmark during the installation process ?
https://www.how-to-hide-ip.net/browse-danish-ip-address/
Not sure if it would help ?
Does it need to access the internet to install the expansion ?
SOURCE: I need the installation code for
hey there welcome to fixya
please follow this link there you will find an installation code for sims scroll down the page you will see it clearly
click here
i hope this was of great help to you
thankyou for using fixya
please remember to rate this solution thankyou
regards
magical ink
SOURCE: Sims 3 code, please
hi,
try this 1300-3992-43818-1841
alternatively go here http://keygenguru.com/search/?search=sims+3&key=Search and click on the sims 3 link and then download the crack/keygen and then use it
