20 Most Recent
Apple 24" iMac Desktop Questions & Answers
I want to transfer a photo from my iMac to my iPad?
hook up your ipad to your imac and use itunes to transfer the picture. with itunes, you can transfer all your pictures, music videos and more. itunesw is how you do that with the ipad or iphone. hope this helps you.
How do i copy a YouTube video to DVD on a Mac computer?
First of all, you need to download MACTUBES, a program for Mac which allows you to copy videos from YouTube to your computer. Second, you need an external drive for Mac such as the USB SUPER DRIVE where you can insert dvds. From there, use any program you have to burn the video onto a dvd.
Sims 3
No problem.
Here is what you need to know:
The regional code for the US is (1).
You can change your DVD Region code up to 5 times on your Mac.
Review the information on DVD Regional codes via this Apple Support link to change the region code:
DVD Region Codes - DVD PlayerLet me know if this Apple data helps!
Regards,
-Mactechtrainer
How do I get a visual on the netflix movie that is playing? I can hear it, but the screen is white.
HI Jennie
If your using a recent Mac with say Maverics OSX then it may be in an off screen window.
Try these Keys
Ctrl & Page up (Arrow Key).... then Choose Movie Window
Ctrl & Page down (Arrow Key)....
The Settings for this are kept in Settings / Mission Control
I think this will allow you to see the offscreen alternate windows.
Netflix is an on line Internet player from a Paid service.
I don't use the same method or app as you so I'm not sure this will work. I use an Application to play movies from my external hard drive and I get the same off screen window that you seem to be describing.
Good Luck
Trevor
Other Notes:
I use VLC to play all my movies of my hard drive (a free download & it plays every codec type avi, mp4 etc) I keep the Icon for VLC in my bottom dock.
When I double click the VLC icon in the dock the window switches to the current movie playing,
If your using a different movie player program then just double click it's icon in the bottom dock. (e.g. Quicktime Player)
If you do switch to VLC then use the Cmd I (Info) on each type of movie (e.g. .mp4) In the Cmd I , Menu , choose "Open With" and select VLC as the preferred player (after you have installed VLC of course) then click the "Change All" button.
From then on all MP4's movie types will be played by VLC.
Imac intel will not power on
Possible failed video card. 3rd LED indicates MLB and GPU are communicating: (CAUTION! There is high voltage from the powersupply so any attempt to open iMac other than removing glass panel to see the indicators...should be done by authorized ACMT)
- LED 1 - Indicates that the trickle voltage from the power supply is detected by the main logic board. This LED will remain ON while the iMac is connected to the AC power. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power is disconnected or the power supply is faulty.
- LED 2 - Indicates that the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
- LED 3 - Indicates that the computer and the video card are communicating. This LED will be ON when the computer is communicating properly with the video card. If LEDs 1 and 2 are ON and you heard the startup sound, but LED 3 is OFF, then the video card might be installed incorrectly or need replacement.
- LED 4 - Indicates that the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
IMAC SCREEN FREEZES OR GOES BLACK.
same thing happens to me - most of the time it will just randomly freeze; occasionally i get an unresponsive black screen. this 24' aluminum imac usually has startup problems also - sometimes it will "gong" and nothing else; sometimes the apple logo will come up and then nothing else; sometimes it will load the logo and then spin for a few seconds and then freeze - the only option is to manually shut down. there is no rhyme or reason to it
How can I use my second monitor on the iMac via VPN/RDP?
Hi Jessiejeh55,
It sounds like you are using the Microsoft Remote Desktop Connection client for Mac.
- Open Remote Desktop Connection
- Select the connection you wish to use with both displays
- Right-click and choose Edit
- Check the "Use all monitors" box at the bottom
Thanks
