Precor 1995 Treadmill
SOURCE: Precor M9.21 Treadmill - Stops under load
This probably did not happened suddenly right? the problem is not the motor however you can easily check the blue capacitor for peace of mind. with the power disconnected, disconnect one side off the capacitor from the top. with a ohm meter put the 2 probes on the cap,you will ear a temporary beep sound from your meter, then reverse your probes on the capacitor and again a temporary sound that mean your capacitor is good and your motor will run OK.
Your problem is more then likely your run belt and bed assembly. When new, these are coated with a wax of some kind for slipping, has you use the machine wax wears off, and so is the belt. You can see a black rubber dust at the rear of the machine. And so resistance increase when pressure is applied on the running belt.
Just behind the on/off switch where the power cord goes in, there is a auto reset 15 amp breaker that trips when too must resistance against the motor increase the amperage over 15amps. At 7 min/m on your speed setting and if the belt is adjusted correctly with nobody on, the motor pull about 6amps, with someone like me 180lbs, the motor pulls an avg of 10amps with a new belt.
If you have a clamp amp meter you can test it yourself.
2 parts you will need to fix this; 50985-101 (bed assembly) and 36355-101 (run belt 17 X 110) This is real easy to install.
make sure these parts are for your machine model # as they did increased the width of their belt over the years
Since 1998 I had to replace these parts 2 times with an average of 3 people using the treadmill every day. This is a good machine and if everything else is good it's worth it. I paid $300 for these parts, i'm sure if you shoppe a little you can do better.
Have a good one
Ben
SOURCE: treadmill deck repair
MDF is what most companies use, but it varies. I'm not familiar with HP treadmills, do you mean DP?
It doesn't matter, I always use desck from the manufacturer. I have modified a deck from one model and used it on another, but I always use one specifically made for treadmills because the surface preparation they do is very flat and very smooth, far better than typical luber prep or anything I can do in my workshop.
You need the deck to be strong yet flexible, very flat, very smooth and very well lubricated.
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
SOURCE: Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Karlisles if there's a repairer closer they'll tell you.
Workshop:
2 Haran Street,
Mascot, NSW 2020
Australia
(see map below)
Postal Address:
PO Box 7250
Alexandria, NSW 2015
Australia
Calls within Australia:
Ph: 1300 308 435
Fax: (02) 9700-9951
International calls:
International Phone +61 2 9700 9759
International Fax +61 2 9700 9951
Email [email protected]
