Check the door interlock switch. They normally run the L1 line through the door switch and if the door switch shorted, the dishwasher appears dead. Good Luck, Eric Campion
Probably one of two different things can cause this problem. Your dishwaser drain could be clogged you can take off the the drain and try to see if it is clear by using a vaccum cleaner reversed to try and blow air through the drain if clogged the air will be strickly hammpered or not getting through at all, if this is your problem then starting at the filtered drain and work your way to where the drain enters the house hold sewer. The blockage will some where between these points. The other possiblity is that the drainiagepump on the dishwasher is bad, you'll have to referre to your owners manual in order to see what it say about testing or replacing the pump. Hope this helps.
If the engine won't crank with compression in the cylinders, either the head gasket has blown or something else major has happened. You will have to get it towed to a shop. If it cranks normally but won't start, you have to figure out if it is a fuel or ignition problem. Did the temp gauge show it was overheating before it died ?
If you've checked that nothing is in the way (no spoons hanging down, etc) just press and hold start and it will start up again and probably won't reoccur for the rest of the cycle. Our dishwasher started doing this near the end of its life....
