SOURCE: caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
SOURCE: How do you set up caller ID on a Norstar M7208
There are a few other things you need before it will just work on your phones. You need to get Caller-Id activated by your carrier on each of the 4 lines. You also need to make sure your system has a Trunk card capable of Caller-Id. The card in your systems should be labeled CID.
After this you still need to program the lines for Caller-Id in the configuration section of programming.
THE RINGING TONE ON THE PHONE IS OK BUT WHEN I PICK UP THE PHONE I CAN ONLY JUST HEAR THE CALLER SPEAKING
already tried this does not make a difference but thanks
