I need to do surds and i dont know hw to turn on the mathIO mode needed to display the answer in surd form. can anyone help!
SOURCE: how do i do a fraction on my calculator
ok i figure this is like any other calculator, but without a fraction button. A fraction i somthing / something . so instead of the fraction button use the division button.
SOURCE: i am trying to get the calculator in
The calculator has two Input/Output modes: MthIO and LineIO. Since I do not know exactly what you mean by "basic math" mode or "basic form" I must summarize some properties of each mode so that you can recognize your "basic math" mode.
The calculator is by default in the MathIO mode. If it not, you can restore it by pressing the key sequence: [SHIFT][MODE] (SETUP) and select [1:MthIO].
To set the LineIO as the default, you press the key sequence: [SHIFT][MODE] (SETUP) and select [2:LineIO].
Hope it helps.
Thank you for rating the solution.
SOURCE: Hi there, I have a
The calculator can't identify that this is a surd unless you input it as a surd, ie as 3/(4*sqrt(5))= when it will then show the equivalent form 3*sqrt(5)/20 (obtained by multiplying top and bottom by sqrt(5)) and you can swap between the two forms using the S<>D button. Even adding the next 4 decimal places (hidden) won't allow the calculator to identify the underlying surd as this is simply too complcated a calculation.
