20 Most Recent Sharp ELW516 Scientific Calculator Questions & Answers
2answers
My calculator will show fractions
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors.
At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers.
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.
There are now two options: 0: W-VIEW, and 1: LINE
Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.
To return to the WriteView display, go through the steps above but press 0 for W-VIEW.
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
5/16/2017 10:22:20 AM • Sharp ELW516... • Answered on May 16, 2017
Perctentage button
Its a secondary function of the digit "4" key (labeled % under the key). Press [2nd F] [4] to access it.
3/20/2014 10:19:29 AM • Sharp ELW516... • Answered on Mar 20, 2014
2answers
What is the nCr and nPr button for?
nCr is Combination. It calculates the number of ways you can choose r items out of n. For example, 52C5 is the number of possible five-card poker hands you can deal out of a deck of 52 cards.
nPr is Permutation. It calculates the number of ways you can choose r items out of n if the order of selection matters.
2/4/2014 4:21:37 AM • Sharp ELW516... • Answered on Feb 04, 2014
How to find the determinant by Sharp ELW516 Scientific Calculator
Press the MODE key. and press 4 for MATRIX. To enter a matrix press the MATH button and choose 2 for EDIT. Determine the size of your matrix by typing in the row x column value (maximum 4). Then press =. Type in the values in your matrix. After each value press = to move to the next part of the table. Once your matrix is complete press ON and then the MATH button. This time choose 4 for STORE. Select the matrix name you would like to store your matrix in - for example choose 0 for matA. Now press MATH and press the down arrow key once. Select 6 for CALC and choose 0 for det (determinant). Then input the matrix you want the determinant of by pressing MATH and 1 for MATRIX. Select the matrix you would like to work with eg, matA and press then press =.
1/20/2014 11:59:06 AM • Sharp ELW516... • Answered on Jan 20, 2014
0answers
Cdf button
Be the first to answer 7/11/2013 3:45:51 AM • Sharp ELW516... • Posted on Jul 11, 2013Be the first to answer
Percent buttonin ELW506X
Sorry but you are not using the command correctly. Here is a screen capture from the manual that shows you all possible calculations with the % button.7_14_2012_10_02_31_pm.png
7/14/2012 10:02:46 PM • Sharp ELW516... • Answered on Jul 14, 2012
tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
Which reset code do I use after adding developer to sharp ar-5726?
https://www.fixya.com/support/t14696300-reset_change_counter_sharp_ar_5726
3/24/2024 6:44:11 PM • Sharp Office... • Answered on Mar 24, 2024
Sharp UX-105 Fax Machine. I am looking for a copy of the manual please?
Question edited for clarity, turned around, added CAPS, added the word 'manual'.Duplicate question should have been deleted but Kardoc has answered, albeit wrong model. Refresh page to see your question when you press 'Post Question'.UX-105 in Russian, or 510 in English, which is probably close enough.https://www.google.com/search?q=sharp+ux-105+manual..
3/22/2024 12:08:51 AM • Sharp Office... • Answered on Mar 22, 2024
Manual for a Sharp UX-105 fax machine please?
https://www.manualslib.com/products/Sharp-Ux-510-641495.html
3/22/2024 12:00:07 AM • Sharp Office... • Answered on Mar 22, 2024
Sharp EL-1197PIII. How to load paper in it please?
Question edited for clarity. Remove the curl out of the paper by running 6" across the edge of a desk against the curl. With scissors, cut the end 1/2" straight. Then cut a 1/2" off both corners at 45 degrees. Push the paper in the slot and press the Feed Button. https://www.google.com/search?q=Sharp+EL-1197PIII.+How+to+load+paper My instructions are better than the video, but shows the process well. ..
3/17/2024 6:09:42 PM • Sharp Office... • Answered on Mar 17, 2024
2answers
AR 5516 sharp printer is showing dotted triangle symbol
Hello, Just replace toner cartridge or refill the toner container with refillable sharp ar202 refill bottle or sachet. Remember to remove waste toner if you are refilling, right.
3/17/2024 8:56:33 AM • Sharp Office... • Answered on Mar 17, 2024
Sharp Printer. How to fix error code L4-17
Error Codes > Sharp > MXC300W > Code L4-17
PrintCopy .info https://printcopy.info > brand=Sharp > code=L4-17 Code: L4-17; Description: Drum motor lock trouble; Causes: Drum motor trouble Connection trouble of the connector and the harness between MFPC PWB and the ... ..
3/16/2024 2:36:24 AM • Sharp Office... • Answered on Mar 16, 2024
How to find input at Sharp calculator?
SCIENTIFIC CALCULATOR OPERATION GUIDE
Sharp Global https://global.sharp > guidebook > documents > s... PDF Enters data for statistical calculations. Splits data used for dual-variable data input. (Used for dual-variable
3/13/2024 10:29:02 PM • Sharp Office... • Answered on Mar 13, 2024
3answers
System lock of my projector sharp 50s ,so how to unlock?
  1. Check the Remote: Make sure you have the remote control for the projector.
  2. Press the Menu Button: On the remote, press the "Menu" button.
  3. Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
  4. Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
  5. Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
  6. Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
2/28/2024 3:14:05 PM • Sharp Office... • Answered on Feb 28, 2024
Sharp ELW516 Scientific Calculator Logo
20 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
  • Office Equipment & Supplies
