Sony bravia tv, cannot turn on with remote, tried turning off at mains but red light still flashes.TV won't turn on. please help
SOURCE: Sony Bravia LCD TV red light on the bottom of TV
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help....
SOURCE: My Sony bravia kdl55hx800 lcd 3d tv won't turn on
try unplugging your t.v for a few minutes, then plug it back in. if it continues check your owners manual or google your issue. this might be the red flash of death. hopefully unplugging it works. good luck!
SOURCE: hi i getting a flashing
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail. http://focus.ti.com/docs/solution/folders/print/387.html The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail. Check for tips to check the SMPS unit: http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies Thank you for using fixya.
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TV will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
While I'm turning on the TV, it's immediately turning to red standby light which is even flashing and unable to green "ON" light. Red standby light flashes 13 seconds and pauses 2 second, then each is repeating again. I don't understand why ?
My TV model is Sony LCD "KLV-46X300A".
Please help if you have the answer..
THE RED LED SHOULD BE FLASHING IN 2, 3 , 4 ETC SEQUENCES THEN PAUSE AND REPEAT THE SEQUENCE.
GIVE ME THE EXACT MODEL NUMBER AND THE #OF LED FLASHES.
sony bravia red light flashes twice
i have lost the remote and got a universal one instead but now tv just flashes red light and will not switch on
