SOURCE: loud grinding noise from unit when flushed like
take the pump out and haul it outside and spray it off and check in the bottom of the pump to make sure there isn't anything stuck in there. then shop vac the bottom of the tank out to make sure there isn't anything funky in there that would get clogged in the pump. sometimes the out let line gets clogged as well you can buy a drain king ( it's a rubber deal that hooks on the end of a hose and when you turn water on it swells up and sprays water out) then stick it in the outlet pipe and let her rip and see if it lets the water through.
SOURCE: water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
