No. on back of watch is 993546
Seiko watches from this period should have a setting stem that pull out half-way and fully. Pulling the stem out fully permits you to set the time. Pulling the stem out half-way should let you set the date by moving the crown forward/clockwise and set the day of the week by moving the crown backward/counterclockwise.
However, for this to work correctly, the watch must have the correct set stem. I have worked with a number of watches, including Seikos, where a generic stem was substituted after someone accidentally pulled out the crown and stem (Seiko replacement parts can be tough to find in the U.S., especially for discontinued models). If an incorrect stem has been installed, the day/date setting procedure I've just described may no longer work correctly. At that point, setting the date involves advancing the hands to get to the right date; day of the week may not be able to be set at all.
SOURCE: Watch setting instructions SEIKO 7N43 8A39 "A1"
If you are still wondering about this, pull the knob out to the first click. turn one way to set day, turn the other way to set date. Pull out further to set time.
SOURCE: setting time/date on old Seiko
Good News you can find Seiko Digital Watches Instruction manuals from http://SeikoDigitalWatches.com its very good site about Seiko Watches.
Thanks
Kashif
http://VintageDigitalWatches.com
SOURCE: Setting Date. Seiko SGF204 (w/ 7N43 Band) French & English Days.
If you pull out the stem 1/2 way, you set the date one direction, and the day the other. If you pull it out all the way, it moves the hands and sets the time.
SOURCE: Resetting a SEIKO watch
You may can find instructions here:
http://www.seikousa.com/#FAQ
Go through the watches till you find the match.
Rate me, please.
SOURCE: Seiko Diamatic Day Date Automatic Watch No: 219050
I have a Seiko Diamatic 780632. To set the day and date, pull the crown once and wind it upwards (away from you) to set the date; winding it downwards (towards you) will set the day. To set the time, you have to pull the crown twice and wind it towards you.
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
Good luck and thanks for using fixya.
Thanks, I was helped by solution 1 and have clicked on yes, but get no response
