Hey. I have an Inland 58019 ThunderSound 5.1 PCI Sound Card
and I recently purchased a Logitech X-530 surround sound 6-speaker system with 2 rear speakers, 2 front (left-right) speakers, a center front speaker, and a subwoofer. I just hooked up all the speakers. At first, only the front left-right and the subwoofer were working. Then I found the sound card CD and installed a new driver from it for a 6-channel sound system. After I did that, the rear speakers were working. But the front center speaker was still not working. I plugged in everything correctly. The ports in the soundcard are Center/Bass, Mic In, Line In, Front Out, and Rear Out. There is also a DB-15Game/MIDI Port, but that is irrelevant in this case. I plugged the center front speaker plug (orange) into the center/bass port. But it still wasn't working. (Or does center/bass mean center front speaker/subwoofer?) I even plugged it into the line-in port because it was colored orange too. That still didn't even work.
When I read the manual for the sound card, it mentioned in the Appendix B section the "4 Speakers System" (front left-right, and rear left-right), but no front center. Does this sound card not support a front center speaker? Or if it does, what can I do to make it work?
Verify that all cables are plugged in correctly. Make sure the rear
and/or center/sub audio cable is plugged in to the correct port. On
most surround sound cards, the rear audio port is black, the front
audio port is green, and the center/sub audio port is orange. If you do
not have a surround sound card, make sure you obtain the proper adapter
(discussed in the next paragraph) or use surround sound emulation if
your speaker system offers it. If you are not sure if you have a
surround sound card, please check with the manufacturer of your sound
card for details.
Make sure your sound card supports the same amount of channels as
your speaker system contains. For 4.1 systems, it should have a front
and rear speaker jack on the card. For 5.1 systems, the card should
have a front, rear, and center/sub, output. The card should be properly
installed and configured. Please contact your sound card manufacturer
for details. If you do not have a surround sound capable sound card,
you can use the M3D button on the controller unit (if you own a z-560
or z-540) or use the source selector switch (if you own a z-5300 or
x-620). If you do not have any of the models above, you can use an
adapter to split the signal for the front and rear speakers. This type
of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase
this adapter at your local electronic store. Please refer to your
manual if you do not know if your speaker system can emulate surround
sound.
Try connecting the speakers to a portable sound device such as a
walkman or portable CD player. Plug the speakers into the headphone
jack, but make sure the volume is lowered so the speakers are not over
powered. You can do this for both the front, rear, center/sub speakers
to verify that they work. If the speaker system works on the walkman,
then you are experiencing a configuration issue with your sound card.
Please contact your sound card manufacturer.
Check the system Volume Control located in the System tray. Make
sure that the volumes are at a reasonable level and are not checked for
Muting.
Yes there has to be a configuration for the 5.4 surround sound... look if the hardware came with a CD to update the sound driver. or Check if the its correctly configured. on the control panel then click Sound, then depending what windows you have have to lookk for the configuration or properties area and configure as 5.0 or sorround etc.
card for details.
you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300
or x-620). If you do not have any of the models above, you can use an
sound.
Muting.
Make sure the rear and/or center/sub audio cable is plugged in to
the correct port. On most surround sound cards, the rear audio port is
black, the front audio port is green, and the center/sub audio port is
orange. If you do not have a surround sound card, make sure you obtain
the proper adapter (discussed in the next paragraph) or use surround
sound emulation if your speaker system offers it. If you are not sure
if you have a surround sound card, please check with the manufacturer
of your sound card for details.
sound.
To troubleshoot a speaker system where sound is not issuing from all speakers, please do the following:
card for details.
you can use the source selector switch or the M3D button on the controller unit (if available). You can also use an
sound.
Muting.
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating.I would be very grateful for your show of appreciation.
card for details.
sound.
Muting.
card for details.
sound.
Muting.
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
card supports the same amount of channels as your speaker system
contains. For 4.1 systems, it should have a front and rear speaker jack
on the card. For 5.1 systems, the card should have a front, rear, and
center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound
card, you can use the M3D button on the controller unit (if you own a
manual if you do not know if your speaker system can emulate surround sound.
device such as a walkman or portable CD player. Plug the speakers into
the headphone jack, but make sure the volume is lowered so the speakers
are not over powered. You can do this for both the front, rear, center/sub
speakers to verify that they work. If the speaker system works on the
walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
Muting.
card for details.
sound.
Muting.
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
