KitchenAid KSRS27ILSS Side by Side Refrigerator Logo
Anonymous Posted on Mar 07, 2012
My kitchenaid Superba refrigerator has suddenly stopped dispensing ice and water through the door. No hum, no noise, nothing but the light. Any idea why?
  • Anonymous Mar 07, 2012
    I had the ice maker turned off all day yesterday, hoping to defrost anything that might be frozen, but no difference today. But I do have a repairman coming Friday, so it looks like it might be more than I can handle on my own.
kapllc
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Mar 07, 2012
kapllc
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
3203
Points
20
Http://www.partlinx.com/search/SearchImageViewer.asp?cImageURL=http%3A//www.partlinx.com/images/00154/i310437.GIF
listen for micro switch #14 clicking when you press #11 and #17
#7 may be off set or even cracked
remember to unplug the refer when repairing
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 12, 2007
SOURCE: KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve.  The water valve is on the back of the fridge at the bottom.  You will see the water line going into it.
Anonymous
  • 23 Answers
  • Posted on Dec 08, 2007
SOURCE: Kitchenaid Superba Ice Maker quit
Make sure your manual doesn't say something about inline filters, or a float that might be sticking in off position. Depending on how ice is made sometimes they have a float to where water rises so hight then gets shut off to freeze and form the ice.
Anonymous
  • 35 Answers
  • Posted on Dec 09, 2007
SOURCE: KitchenAid Superba KSCS25FKSS00 SideXSide Refrigerator
Replace the ERC board.
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Apr 08, 2008
SOURCE: Kitchenaid Refrigerator Superba
heres a part number for the valve, somple enougth to install just turn off the water supply and installe ne wvalve, exact replacement. soundsas if its not closingt correctly allowing water to tricklel in part number 4389177
Anonymous
  • Posted on Oct 31, 2008
SOURCE: KitchenAid Superba ice maker not dispensing ice
the problem is that the bottom piece is missing from the ice maker housing. i have the same problem and im looking for that peice
3answers
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
2answers
Water and ice dispenser and panel light stopped working.
02227c0.jpg Look at above diagram. #18 needs to be replace. Trim pops off then there will be several screws. Goodluck...
1helpful
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
Kitchenaid superba 42 side by sside water dispenser
usually when i get a kitchen side by side i trouble shoot the wtr valve first by using a cheat cord that applying volatge directly to the vlave to see if it opens but usually the wire harnes under frezeer breaks the wires so my money is on the wires under the frezerr door cut the sleve off and chec the wires one by one the one to the water is broken
11helpful
6answers
this is not a solution, but an explanation- our repair man said that there is a line (tube) containing electric wires that passes from the frig to the door at the bottom of the door, near the hinge. for what ever reason, the line has broken, thus keeping the electric from getting to the motor that dispense ice and water- solution= $700 for a new door; we'll do without
2answers
Ice Dispenser does not work.
Remove the ice tray and clean it throughly with warm water. Let it dry at room temperature and see what happens.
2answers
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
