Was taking over two minutes to fill. Problem was with fill valve.
To resolve problem either replace fill valve or remove the flow restriction. Here is how I done it.
Turn off water!!!!
Remove the supply line.
Inside of the fill valve is a rubber piece. It is about 3/4" in diameter by about 1" long. This rubber piece has become distorted after years of use. This has to be removed.
Believe it or not, use a corkscrew and thread it into the rubber piece that is located in the very lower section of the fill valve. You can't see it so you will have to feel. Pull it out.
Re-connect the supply line.
Turn on water.
Check for leaks.
Problem solved.
NOTE>>> This only works for American Standard fill valves.
