My camera has a white screen when i turn it on but still takes good pictures
SOURCE: Olympus 720 sw LCD Screen blank & white
Just in Time for Christmas then!
So decisions - live with out the screen- it appears to be a connexion failure or a main board failure.
Or replace the camera - a repair will cost almost as much.
SOURCE: BLACK SCREEN, OLYMPUS FE210
You must go to a camera technician. There are some parts inside that already been loosen. That's what happened to my camera before.
SOURCE: Olympus Stylus 710 Problem with lens
Hey,
Westfield46 was right! I tried the recommended fix and it worked! Thanks so much. It turned what I thought was a piece of trash into a usable camera.
Camera Man
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
SOURCE: flash Does not work. Can only take pictures in flash-off mode
The problem you are describing is a problem with the flash charging indicator switch inside the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Ashley, did you get a response at all??
